subframe connector questions, pic request
Discussion in 'Technical' started by xpsnake, Feb 19, 2006.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    I have a local mustang guy who comes highly recommended for subframe connectors. I need to get some pictures of maverick with connectors. I'm also wondering if connectors that aren't "through the floor" are worth putting on.
    He is saying about $250 to build and install the non-"through the floor" type on my maverick. I seem to recall the connectors dan starnes made as being the type that only connected at each end.
    If anyone has pictures of either type of connectors, I'd like to see them. I did find one post involving the through the floor type here on the board that still had pics.
    Thanks in advance.
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Unless you are running over 400 hp,, dont worry bout runnin then thru the floor. He is not overcharging you at that price. There are pics of Mavaholics car somewhere on this board with the connectors on them, I just cant find them now.
    Dan
  3. Mavaholic
    Actually I cant find it either.
  4. bmcdaniel
    I have the Competiion Engineering bolt-ons. Even they make a noticeable difference.
  5. DAB
    DAB MAVERICK/COMET ENTHUSIAST
    Austin, TX
    Subframe Connectors
    Here it is! I've been looking for an hour or so enjoying my Maverick archives! :)
    The reason you couldn't find the picture is because it was under Dennis' car! :D
  6. Mavaholic
    LOL, thats funny cause I finally found it and came back here to post.
  7. 71gold
    a muffler shop did mine...he has a race car... so he had some rollbar tubing laying around and made mine out of that...$75 installed. if you rotate the pic 180 degrees they look like the ones in the pic :biglaugh: :biglaugh: ...frank...:bouncy:
  8. xpsnake
    xpsnake Bruce
    Exactly what I was looking for guys, thanks a bunch!
  9. CACollo
    CACollo Member
    Abq. NM
    1969.5 Maverick
    I had a local guy build mine, also out of roll-cage tubing. Mine are almost the same, except they run along the SIDE of the sub-frames, and get welded to the sides. Couldn't say either was better though!
  10. don graham
    i bought mine erom summit racing. rectangular tubing. cost about $110 and had them welded in for me. they go underneath the floor, but are welded in a number of places.
