Suggestions: How to remove this nut
Discussion in 'General Maverick/Comet' started by Chlorin8ed, Feb 17, 2018.
  1. Chlorin8ed
    Chlorin8ed 72 Comet
    Iowa
    1972 Mercury Comet, 1980 Chevy Malibu, 1987 Chevy R10
    I am attempting to remove the "cover plate" in the wheel well that covers the coil. How does one remove this nut or remove the vacuum canister? to get the nut off?
  2. mojo
    I don't recall having to remove the vac canister on my 73 to get that cover plate off! Maybe the 72's are different.
    Maybe someone else can chime-in w/ their input1
  3. Krazy Comet
    Loosen canister strap, remove canister, remove cannister bracket, maybe two minutes...
  4. Chlorin8ed
    Chlorin8ed 72 Comet
    Iowa
    Thanks Krazy Didn't realize the strap came off and it lifted out. BTW what is the purpose of the canister?
  5. dyent
    dyent Member
    vancouver bc
    Looks like the Charcoal Fuel Vapour canister.........
    David
  6. Acornridgeman
    Wisconsin
    Stores vapors from the gas tank so they can be burned in the engine and not stink up your garage on a hot day .......... :)
  7. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    You'll want to replace your charcoal fuel vapor canister when you're done. The the metal pipe is a gas tank vent. The carbon canister and hose to the air cleaner create a closed system keep fuel vapors from escaping into your engine compartment. New cars use a purge valve solinoid to regulate the release of vapors into the intake, but the elegantly designed Ford system passive system performs very well. No moving parts, no maintenance, should be the last part of the car to wear out.
