summit motorsports park
Discussion in 'Drag Racing' started by HOMERMAV, Jun 18, 2010.
  1. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    well im getting ready for another try at the drag strip maybe i can make it past second round elimanations this time.got the car all ready new gears all new s/s braided fuel lines,a-n fittings and my brand new sa-2005 helmet.had the car on the street a little wow did those gears make a difference.
    john(aka homermav)
  2. drag460
    drag460 T-Shirt guy
    El Paso, TX
    Good luck! (y)
  3. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    thanks drag460
  4. don graham
    Have fun. Let us know how the gear change works.:)
  5. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    :chirp:
    you bet don i will let you know about the gears.
    as far as fun you bet i'll have a blast
  6. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    what gears did you have and what do you have now?
    Good luck!!!
  7. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    john i had 3.50s before now i have 4.11s
  8. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    what rpm are you shooting for and where was you with the 350's
  9. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    looking for around 5500 rpm and before i was turning 4800 thru the 1/4 at 98 mph 13.61 et
  10. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    should be close of everything else is the same....I would venture you will be on the higher side of 55 but you will find out soon enough :D
  11. HOMERMAV
    HOMERMAV Member
    NW.OHIO
    1971 MAVERICK
    my cam is suppose to be good to 6200 so i think im in good shape and i have my rev limiter set at 6000
  12. Wilbur Green
    Wilbur Green Member
    Plymouth, Ohio
    76Stallion, 762dr.
    Good luck John, let us know when your up.
  13. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    Careful around 6200 you'll get some mean valve float.
