Sump and Headers- will these fit?!?!
Discussion in 'Technical' started by topcat, Aug 23, 2010.
  1. topcat
    topcat Member
    Essex, England
    '71 Grabber 302
    Hi people, not a mega choice of stuff for Mavericks and Ford V8's over here, so can some of you tell me if this sump will fit my standard 302 Grabber, and if these headers will fit (302 C4 auto will convert to cable linkage) although they look like 1.1/2" and I would prefer 1.5/8" primaries...
  2. Fordmaster169
    Fordmaster169 Member
    Coos Bay, Oregon
    A Mustang II has a rear sump pan, it will not work in a Maverick in its stock configuration. If that is in fact a Mustang II oil pan then the pickup is not the correct one.
    The headers are another matter, you will need to ask the person what the part number is on them. You cannot just look at a set to see if they fit or not.
    Good luck
  3. topcat
    topcat Member
    Essex, England
    '71 Grabber 302
    Cheers yes I should have just asked you if a mustang was front or rear sumped...
    With the headers I wasn't sure if the ones to fit a Mav were a distinctive shape or anything!
  4. Bob Wiken
    Fayetteville, Arkansas
    Mt driver side header has a hooker emblem and the model 6901. those are the ones that will fit
  5. Purple Nurple
    Purple Nurple Member
    Edmonton, Alberta
    72 Maverick ,347, Art Carr C4, 4.56 9" spool
    Pretty sure that's a front sump oil pan. You can see where the flange kicks inward which would be next to the starter. Should fit but it will be very close to the belly bar.
  6. topcat
    topcat Member
    Essex, England
    '71 Grabber 302
    Will any 302 front sump fit or are they car specific?
    Also- am I right to assume 1.5/8" headers will be the best choice?
  7. bmcdaniel
    Wonder why my 6901s don't have an emblem or model number on them?
  8. Purple Nurple
    Edmonton, Alberta
    Your Maverick will take the pan you're looking at. It's the Mustang II that needs a specific pan so that it does hit the rack, and yes, they are front sump as well. If you don't go for the pan you're looking at on Ebay (you have 1 day left), avoid the oil pans with the big square kickouts at the bottom as they may hit the chassis right below the motor mounts.
    Headers: The 1.5" primaries will be enough unless you're planning on running over 6000 rpm. They'll give you good bottom end torque.
    Good luck.
  9. Purple Nurple
    Edmonton, Alberta
    i meant doesn't hit the rack
