Surpise Surprise Surprise
Discussion in 'General Maverick/Comet' started by steelhorse5778, Nov 28, 2010.
  1. steelhorse5778
    steelhorse5778 Member
    well today i took on the undertaking of swapping out the rear ends from the donor car to the car im building and i found a nifty little surprise. underneath of the car im using i found a rear end that i dont recognize. the casting numbers are c90w 4025a. i tried to google it with no luck. the thing that struck me as odd is that it does not have a removable center section like the 8" and 9". instead it has a differential pan in the rear with the drain plug in the front. any ideas as to which rear end it may be? and as i side not this must be the smallest one ever made because the 8" dwarfs it.
  2. rwbrooks50
    rwbrooks50 Member
    Forney Texas
    71 Maverick & 63 Ranchero
    Sounds like the 7.5 rear from the early 69.5 & 70's. Is it a 4 or 5 lug?
    Rick
  3. mav1970
    Yep, sounds like a 7.5 rear - same as the one I took out of my 69.5 and couldn't throw it away fast enough :yup:
  4. steelhorse5778
    it is a 4 lug
  5. mav1970
    It's a 7.5 rear
  6. darren
    Yep its the little baby diff. Very weak. My 70 had that diff.
  7. rthomas771
    Can't be a 7.5 cause Ford never made one. It could a 7.25" or worst yet a 6.75" or 7"
  8. darren
    7.25 in the early Mavs.
  9. 302-72-mav
    302-72-mav Member
    sactown CA
    ha ha before swaping mine i welded the spyder gears up and burnt the tires off of it :thumbs2:
    then i pulled it and put the 8'' in then a little bit after that i put a 9'' in it
  10. Mad Goon
    Mad Goon Scaring the Hondas
    Redondo Beach, California
    Ah sounds like the rare 9" that my buddy had in his boss 302 Maverick that came like that from the factory lol
  11. mav1970
    I just knew it was little :yup:
  12. steelhorse5778
    so what your saying is i should make it into a table.
  13. starsky74
    starsky74 Technician
    Hackberry Louisiana
    my buddie had one a dem too.mm hmm!!!!!;)
