Suspension Kit
Discussion in 'Technical' started by Canuck, Jan 29, 2011.
  1. Canuck
    Canuck Member
    Calgary, Alberta Canada
    1973 Comet
  2. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    you may need to wait for someone else to chime in but I believe 71 front end mustang stuff should fit comets and maverick front ends.
  3. injectedmav
    injectedmav Member
    Georgia
    Most of the stuff should bolt in with the exception of the sway bar. The arms in the picture show a 4bolt ball joint but I don't know for certain if the arm is different otherwise. I know Mustang guys use Maverick spindles for disc brakes but maybe someone else knows for sure. I'm pretty sure the sway bar won't work though.
  4. PaulS
    All the parts except for the sway bar are exact fit.
    Sway bars and idler arms are different.
