suspension stuff..
Discussion in 'Technical' started by PINKY, Oct 15, 2006.
  1. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Whats the pro's and con's on eurythene verses rubber on all my suspension components?
    Going to order a rebuild kit for the yellow car.
    Thanks.
  2. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    pros: last longer , handle alot better
    cons: if you dont give them some grease before you install them you will have a sqeak
  3. Jamie Miles
    I have always been under the impression that urethane is better for race applications that see little street use, whereas rubber is better for all out street cars due to quietness and better ride quality.
  4. Max Power
    Max Power Vintage Ford Mafia
    St. Paul, MN
    Both posts are correct. I found that when using all poly with supspension components that are made for rubber, you can also run into problems. Poly sway bar end link bushings on my Mustang II ended up snapping the end links off due to a poor design of the end links by Ford. I had the choice of going back to rubber or fabricating a different design end link. It was easier just to go back to rubber.
  5. |MaverickMat|
    |MaverickMat| '74 Grabber
    Portland, OR
    1974 Grabber
    But make sure you grease those poly bushings, 'cause there is NO sound in the world more annoying than a squeaky bushing. :banghead:
  6. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I have the P-S-T polygraphite stuff in my front end. With the KYB Gas-A-Just shocks, it is a little stiffer than I like. When totally cold, you feel and hear every little bump. Once it warms up-driving, it softens a bit. For your 6 cyl. car I'd go with rubber. That is assuming you aren't going racing with it.
  7. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    They squeak even if you grease them. They don't rot like rubber (so they last a lot longer), and they are more stiff, so handling is better. Ride is stiffer too, which can be annoying for some people.
    As for end-links; you can buy the correct ones from Pep Boys and AutoZone, and they are not expensive. They use a Grade-5 3/8" bolt with a Nylock nut. It ain't gonna snap...
  8. bmcdaniel
    bmcdaniel Senile Member
    Every spring part of my ritual is greasing up the urethane bushings in the rear springs and front sway bar. I'm going back to rubber soon. The stuff they sell now for "rubber" is actually better than what originally came on our cars, a little stiffer and holds up better, but doesn't squek.
  9. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Del alum bushings for ever:bowdown: :D
  10. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    Thanks.
    Its not going to be a race car.....well, not like PINKY. Going with a stroker motor. :evilsmile
