swap pix.
Discussion in 'General Maverick/Comet' started by ncmaverick1977, Nov 6, 2011.
  1. ncmaverick1977
    ncmaverick1977 Member
    Burlington, Ia
    1977 Maverick
    I finally posted some pictures from my 302-5 speed swap in my gallery.
  2. maverick75
    Looks awesome! :)
    What headers are those?
  3. strokermaverick
    strokermaverick Member
    Very nice! I really like the long shifter handle with the bench seat. It reminds me of the "ALL BUSINESS" '70 1/2 Falcon 429 CJ 4 speed.
    I am planning on doing the 5 speed swap to my '73.
  4. ncmaverick1977
    Burlington, Ia
    1977 Maverick
    Thanks. I like the no frills look, too. The headers used to be Hedmann shorties. I had to adjust them a bit to clear the pitman arm. I did the passenger side as well to get a better angle near the firewall.
  5. ncmaverick1977
    Burlington, Ia
    1977 Maverick
    The 5 speed turns it into a completely different car-way more fun.
  6. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    Looks good. Watch out for that air cleaner though. One bad backfire and that foam will melt and fall into the carb. The guy that decided to put non flame retardant foam over a carb needs slapped.
  7. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    I like it:thumbs2:. I got some stock '74 pedals from ebay in hopes to one day do the swap...way more fun IMO.
  8. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    I see you bolted your CNC master cylinder up the same way I bolted my Willwood up. :thumbs2:
    Guess my question is does the pedal bottom out on the cylinder a couple inches away from the floor like mine does? If it does you might want too look at putting a bump stop in on the pedal its not neccisarily too good on the MC to keep bottoming it out.
    Your setup looks awesome great job, and yes I agree the 5 speed makes the car allot more fun, and I love the hydraulic clutch setup. It doesnt wear your leg out like the old linkage borg and beck clutches have a tendency too do.
  9. ncmaverick1977
    Burlington, Ia
    1977 Maverick
    Thanks. I've heard that about the air cleaners. I never have liked it. I'm going to replace it with something less risky and less ugly.
  10. ncmaverick1977
    Burlington, Ia
    1977 Maverick
    Seems like it bottomed out at first, but I was able to screw the push rod in at the pedal to get it closer to the floor. It's not as light as I thought it would be, either. I don't know whether it's because I couldn't use the outer hole on the clutch fork or some other reason. I purchased a bracket for mounting that slave cylinder, but even with the bracket shimmed out, there was a bit more angle on the push rod than I wanted, so I used the inner one. It's not bad; just not as easy as I'd anticipated.
  11. 302-72-mav
    302-72-mav Member
    sactown CA
  12. Bob Wiken
    Fayetteville, Arkansas
    I've not seen valve covers painted that way. I like them a LOT better than m,y Ford Blue ones
  13. ncmaverick1977
    Burlington, Ia
    1977 Maverick
    Thanks. I wish I still had my Powered by Ford covers. I'd have painted them the same color. I think it's the "cast" color in a spray bomb from Autozone.
    To 302-72-Mav: I'm pretty sure I emailed you with questions before I started. Thanks for the help!
  14. 71gold
    ...liking the headers...:yup:
    I did a set of shortys like that for my 347...:thumbs2:
