swaping efi 5.0ho into maverick 02 sensor?
Discussion in 'Technical' started by jaxster010, Jun 1, 2012.
  1. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    do i have to run my 02 sensors on my efi 5.0 swap in my maverick. will the car run without it.
  2. Clintd
    Clintd Member
    Parlin NJ
    75 maverick, 89 Cougar (sleeper), 04 Superduty and a 87 Cougar
    for EFI you have to run at least one. You can tie the signal wires together and run only one O2 and be OK. make sure the sensor is as close to the engine as possible and not on the very bottom of the pipe.
  3. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    ok cool thanks man
  4. Bryant
    it will run with out the o2 sensors. it wont run as well as it can.
    i would put the wiring in for the o2 sensors, then when you get it running, goto an exhaust shop and have them weld in the o2 sensor bungs and put the o2 sensors in.
  5. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    ok cool on my wiring harness its says kapwr-black/orange
    and..............................................fpm-pink/black........what does that mean..iam runing it to my fuel relay but not shore where it goes on my relay 30,or 26.....
  6. Clintd
    Clintd Member
    Parlin NJ
    What year make and model ECM and wiring harnes are you using? When I get home I'll post up the schematic's.
  7. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    88 to 91 efi 5.0 ho mustang with aod tranny.
  8. Clintd
    Clintd Member
    Parlin NJ
    I can also burn a chip to adjust for a larger MAF or injectors and delete EGR, air pump, and perg valve.
    I'm still at the airport but I'll post up the schematic soon.
  9. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    ok so i can delate egr and car will still run
  10. 71gold
    ...or AOD-E...:bouncy:
  11. Bryant
    yes you can delete the egr. the car will still run.
    now you will get better gas mileage with the egr than you will with out it. the computer controlled egr systems work well when properly set up.
  12. Clintd
    Clintd Member
    Parlin NJ
    On one of my project cars I deleted the EGR only because I didn't have the tube for it. Eventually I made a new tube and reprogrammed the ECM for the EGR. There were no noticeable performance differences but I did gain 2mpg's in city mileage.
  13. Clintd
    Clintd Member
    Parlin NJ
    No FOX mustang came with a AOD-E, only the AOD. SN95 and up had the 4R70W (AOD-E).
