swapped efi 5.0 into maverick starter want shut off
Discussion in 'Technical' started by jaxster010, Jul 23, 2012.
  1. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    i swaped a efi 5.0 into my maverick and the car starts up but starter keeps going lol sorry best way i can explain it
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Soleniod sticking? Maybe you have the wrong starter that sticks too far into the bellhousing.
  3. Rick
    Rick G8I operations
    Ocala, Florida
    How do you have it wired? a mini starter will do that if the solenoid is not isolated since they are a permanent magnet motor.
  4. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    stock everthing
  5. Joe Dirt
    Bad selonoid or the wrong wire to the selonoid
  6. Rick
    Rick G8I operations
    Ocala, Florida
    Do you have the big 302 starter with one connection or the small 5.0 mini starter with the solenoid on it?
  7. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    yea the big 302 starter it will start over fine and when i touch the red and green wire to it it starts up but it want catch and stay runing
  8. Rick
    Rick G8I operations
    Ocala, Florida
    If it stays running the like Joe said it might have the wrong wire connected to the "S" terminal on the solenoid keeping it energized.
  9. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    i have a run wire red wire with green strip and a start wire red with blue strip hanging off my tfi so i hooked it up to the same colors on my maverick and it starts but starter keeps trying but car want run on its own .... sorry if i lost you iam so confused
  10. Rick
    Rick G8I operations
    Ocala, Florida
    Red with blue trace should be connected to the "S" terminal on the starter Solenoid. The Brown wire or Red with green to the "I" terminal on the solenoid.
  11. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    iam using a 91 mustang solinoid
  12. Dave B
    Did you use the starter that was on the engine and transmission? or did you actually change it to the older style?
  13. jaxster010
    jaxster010 Member
    tampa, fl
    1971 Ford Maverick
    no iam using the starter that came on the 91 mustang but iam using a 91 mustang soilnoide do i need to get a older starter soilnoid
  14. Dave B
    A 91 would come with what everyone refers to as a mini starter, the solenoid is on the starter.
  15. Rick
    Rick G8I operations
    Ocala, Florida
    Looking in the catalog here the 91 mustang still had the big starter, the PMGR mini starter came out in 92.
    The Mavericks Red w/blue trace wire should be the only wire connected to the S terminal or small connection on the 91 Solenoid. You might want to replace the solenoid with the older version so you can connect the other small ignition wire.
