Switch to 4.22 ratio
Discussion in 'Drag Racing' started by Ol Maverick Man, Nov 21, 2010.
What ratio should I use. 4.11 or 4.22
  1. 4.11 ratio
    18 vote(s)
    90.0%
  2. 4.22 ratio
    2 vote(s)
    10.0%
  1. Ol Maverick Man
    Ol Maverick Man Member
    Wallingford, Ct.
    1973 Maverick Grabber Clone
    I'm trying to decide whether to put in a 4.11 or 4.22 ratio in my Maverick.
    I have an AOD transmission. I'll be driving mostly on the street, with an occasional trip to the drags. Would appreciate everyone's opinion.
  2. my70mav
    my70mav Member
    Elk Grove,ca
    69.5 maverick
    the fox mustang swear by the 4.11's for use with the ad
  3. 302-72-mav
    302-72-mav Member
    sactown CA
    i hear that 4.11's are hard on a t5 5 speed trans on the freeway
    what motor are you going with ( SPECS )
    are you going to use it on the freeway // is it a every day driver from point A to point B
    look on youtube and see if you can find a car with the same specs as yours with 411 or 422 and see how it drives and shifts
  4. Ol Maverick Man
    Wallingford, Ct.
    The engine is a 302 with Windsor heads, headers, cam, MSD ignition. 600 or 750 holley mechanical secondaries. The transmission is an AOD, automatic transmission with Overdrive.
  5. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    I have 302 performer rpm heads,crane cam ignition,headers, 750carb,cam,and intake,I also have c4 with a 2800 stall,got the 411's in my car and really don't see anything bad with them...only on the highway,I'm hitting bout 3000 at around 65 70 haha
  6. PaulS
    More gear is always better....:)
    The 4.11s will work but the 4.22s will be even better (not that you will notice much difference.:huh:
  7. brainsboy
    brainsboy Member
    Tampa
    Im surprised at how many people responded without even knowing your overall tire diameter. If you really want the best of both worlds run the 4.11's and buy a second set of rear wheels and run 1 inch smaller tires, which should put you at 4.2X's overall for the track.
    If you have a 26" and 4.11's then swap out to 24" rear tires puts you about the same as running 4.50 gears.
  8. bossmav
    bossmav Drag racing nut
    Harrisonburg, Va
    74 Grabber now Pearl white
    Brainsboy has a good point, you can always also go taller to a 28 inch tire for the street but I wouldn't go lower then the 4.11 for street use.
    Besides 9 inch 4.11 are a dime a dozen.
  9. Ol Maverick Man
    Wallingford, Ct.
    Thanks for all your opinions. I've descided to go with the majority. I ordered 4.11's today.
  10. 69shelbmet
    69shelbmet Member
    USA.
    77 Comet.
    Yes that would most likely be your best bet, however I am sorry I missed this post because I have a rear that will be going in with 4.62s because of cam and stall selection as well as monster tire hieght. But I believe the 4.11s to be best suited to your application as well as most. Since I have not done the math I may have to switch the gearing in this car to 4.22 or even 4.11. :huh:
  11. 69shelbmet
    69shelbmet Member
    USA.
    77 Comet.
    For my application, here is the math =We can figure rpm at 65 mph by doing this: 65mph X 0.67transgear X 4.62reargear X 336 =67603.536 then dividing with the tire's outside diameter 32.50" wich equals 2080.1088 or roughly 2,080 rpm. Gee that will wreak havoc with converter but is just above the cams poor line this might need a manual trans after all.
    I think Iwill start saving for a jerico 4 speed.
    :rofl2: I'm in trouble now! I !...Can't! ..Drive!......55!
    Now, lets find out 3rd @ 65MPH in an Aod. =3,104.64 RPM this would be the same as third in a C4 or C6 with my tire and rear gear.
    Long live the Mavets and Comricks! Anyone with any tech correct this, if I have made any mistakes please let me know.
  12. bmcdaniel
    bmcdaniel Senile Member
    The difference between a 4.11 and 4.22 is only something like 2.7% increase. I don't think you'll notice either way. Where you would turn 6,500 rpm with 4.11s, the 4.22s would turn 6,675 rpm.
  13. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    I voted for... wait... I forgot.
    :rofl:
  14. tazbm193
    tazbm193 Member
    florida
    ford
    4:11 ratio
    Save your money. You will not notice any difference in performance between the 4:11's and the 4:22's ratios. If you can go through the traps at your peak maximum RPM range you are ahead of the game. If you still need more gear try a shorter tire, it's cheaper and takes less time to swap. Good luck
