Switching to 15" rims
Discussion in 'Technical' started by soooulpower, Dec 17, 2008.
  1. soooulpower
    Mapleton Depot, Pennsylvania
    Well, I'm getting ready to order a few parts for the mav next year and rims are on the list. I'd like to put 15's on it. Will there be any clearance or rubbing issues?
  2. Mavaholic
    Depending on width and offset, nope.
  3. don graham
    Like Dennis said, no problems if you are using the standard rims and tires. The problem is if you want to go to a real wide tire.:)
  4. rthomas771
    You can't use some old pre-'75 factory steel wheels and some old style mags because they will hit the brake caliper if you have disc brakes.
  5. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    Upgrading to the 15 " wheels will be one of the BEST mods that you can make. Good Luck Dude!
  6. soooulpower
    What should I keep in mind as far as offset?
  7. soooulpower
    No plans to go that route. (y)
  8. soooulpower
    Yeah, I always wanted to get custom rims and figured why not go the extra mile...No pun intended. Thank you for the well-wishes.
  9. soooulpower
    On a side note I have a list of cars with the same bolt pattern as the Maverick. Does this look right to you? I still haven't seen a search for maverick rims that has turned up with a result. I have a set of Mustang svo rims I want to get, but I wanted to make sure they fit.
    Here's the list:
    AMC Gremlin, Hornet, Pacer, Javelin, Matator, AMX
    AMC - most models (exc. Jeep) '40-'89
    Chrysler/DeSoto - all full size RWD cars (exc. Imperial) '37-'89
    Datsun/Nissan - 1600-2000 '65-'73
    - 300ZX, 200SX V6 (some) to '89
    Dodge van
    Dodge 1/2 ton P.U.
    Dodge - all full size cars & P.U.'s '37-'89
    - Dart, Demon, Swinger '73-'80
    Ford 1/2 ton van
    Ford Granada, Monarch
    Ford - All full size cars '49-'72; '79-'85
    - Fairlane '62-'79
    - T-Bird '55-'71; '77-'79
    - Mustang 5-bolt '65-'73
    - Maverick 5-bolt all
    - Mustang SVO '85-'86
    - Ranchero '68-'84
    - Aerostar, Probe, Bronco II/Ranger to '89
    Hudson - all '48-'56
    Lincoln - all '70-'72; '80-'89
    Mazda - RX7 Turbo, 626, 929, MX6 '86-'89
    Mercury - all full size cars '52-'54; '61-'72; '79-'85
    - Cougar '67-'79
    Mopar '73-up "A" body
    Plymouth - all full size cars '37-'89
    - Barracuda '70-'74
    - Duster, Valiant, Volare '73-'80
    Pontiac - Tempest, LeMans '61-'63
    Studebaker - all '51-'66
    Toyota Crown, Hilux P.U.
    Toyota - 2WD P.U. '69-'89
    - Supra Turbo '86-'89
    Volvo 122, 1800
