t-5 and drive saft length
Discussion in 'Technical' started by GrabberGT, May 15, 2006.
  1. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    t-5 and drive shaft length
    Question for those of your with a 302 - WC t-5 - 8" rear combo. What is the length of your drive shaft? I need to have mine cut down but do not yet have the tranny installed to measure the length. I do however need to get my drive shaft in to the shop ASAP.
    Thanks
  2. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    115.00 to shorten and balance? Does that sound fair?
  3. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    my old d/s fits like a glove, spline even lined up. I wonder why these cars vary so much with fitment
  4. boss351maverick
    boss351maverick Member
    cleveland,tennessee
    Boss 351 powered Maverick, daily driver
    Just FYI, 6 speed and aluminum driveshaft out of a '03-'04 Cobra fits w/o mods. Only need crossmember mods and adapting rear u-joint. C6 and same driveshaft with a C6 front yolk are the same lengths overall. If you are going to have a driveshaft cut down, get an aluminum one out of a late model Explorer. It has an easier u-joint to adapt.
  5. bmcdaniel
    Some guys with T5s use a cable instead of the old mechanical linkage. With a cable the engine block doesn't have to be aligned as accurately front-to-rear as when you have an EQ bar that has to move freely. A 1/2" front or back can make a difference.
  6. Mavaholic
    I paid $210 for a complete heavy duty drive shaft.
    :biglaugh: Thats good Barry, first time I notice that. :clap:
  7. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    Oddly enough, the driveshaft did not have to be modified at all. Even the yoke from my c-4 slid right in and has about 1 inch of play.
    Thanks for the help guys.
