t 5 help aad stock cultch need help
Discussion in 'General Maverick/Comet' started by classic ccg, Apr 8, 2012.
  1. classic ccg
    ringgold GA
    72 maverick
    t 5 transmission and stock z bar? whats a z bar? and i had a 170 ci on the tree
    so i have the cultch pedal.
    what im trying to ask if if i can se the set up i have now foor a 5 speed. i dont whant to use the tree . i want it to be on the floor
    and whats a good price for a 5 speed in GA?
  2. classic ccg
    ringgold GA
    72 maverick
  3. Ryan
    Ryan Ford Addict
    Phoenix Az.
  4. rthomas771
    Z-bar is slang for equalizer bar, you will need an adapter between the trans to bell housing. This adapter will take up the 5/8" difference between the longer input shaft on the 5-speed transmission...assuming you're using a 170-200 6 cylinder. $70 will get you a 5-speed at Pull-a-Part
