T 5 rebuild
Discussion in 'Transmissions' started by Dean Deeter, Oct 9, 2015.
  1. Dean Deeter
    Dean Deeter Member
    West Carrollton, Ohio
    1974 Comet GT and 1974 Maverick
    I am going to rebuild the t5 I bought. I have a few questions. The counter shaft looks to be not rebuildable. Is that correct. If I buy a shaft that has the same number on it is it the proper grear ratio. I will get a picture posted of the main gears later. I think it is the 4th gear that is bad. WP_20151008_19_04_28_Pro.jpg WP_20151008_19_04_16_Pro.jpg
  2. Bryant
    the shaft is not rebuildable. 4th "gear" does not use any gears in a t5. it locks the input shaft to the output shaft to create a 1 to 1 ratio. it looks like second gear to me.
    you need to get the countershaft with same teeth counts. thegearbox.org is a great source for t5 parts.
  3. fuelish351
    fuelish351 Member
    San Jose, CA
    73 Maverick Grabber 2.3 Turbo
    Yes the 052 is the number for that cluster so you will need to find one with the same number, I know the 4cyl ones are 048
  4. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Looks like a great source, thanks!
  5. Dean Deeter
    Dean Deeter Member
    Thanks for the info. Now here is a picture of main shaft . What gear is torn up? WP_20151010_09_32_09_Pro(1).jpg
  6. Krazy Comet
    That's 3rd, it's the weal link in the pre '89 OEM T-5(busted one of those myself)...
    It's possible to upgrade to the stronger '90/later gear set but won't be cheap, cost me like $600 in parts 20+ years ago(that did include the rebuild kit with bearings, seals etc)...
  7. Dean Deeter
    Dean Deeter Member
    Thanks, I believe I am going to just replace the gear. I bought this like it is I think they were a little harder than what I will be. Where do you sugest I look?
