T-56 on a 302
Discussion in 'Technical' started by theoFFbits, Jan 23, 2016.
  1. theoFFbits
    theoFFbits Member
    Israel
    ford maverick
    Hey guys it's been a long time since I last posted here something, but I'm back with a question: I may got my hands on a t56 gearbox. The question is will it fit the 302 engine? And if not, what engine will it fit on? Thanks alot. Assaf
  2. Krazy Comet
  3. tody
    tody Member
    cologne, germany
  4. theoFFbits
    theoFFbits Member
    Israel
    ford maverick
    But it's possiable to connect the two? Or would you suggest getting the t4 for the 302?
  5. mojo
    Probably be easier going w/ WC-T5. From what I understand the T56 is larger than the T5 , may need some mods to the trans tunnel. Maybe someone here may have done this upgrade and will chime in. Gud luck with it!
  6. 71_Maverick
    71_Maverick Member
    michigan
    T56 can bolt up to a sbf with an aftermarket bellhousing no problem. Your going to run into problems in the tranny tunnel.
