T5 conversion
Discussion in 'Transmissions' started by aggie2390, Dec 24, 2010.
  1. aggie2390
    aggie2390 Member
    TX
    1973 maverick
    I just started my T5 conversion and i'm making a new trans mount for it so i'll post my progress and ideas and see what y'all think. I'm making the mount out of square tubing and for a better drive angle i'm lowering the motor 1/2". Hope it all goes well!
  2. Bryant
  3. aggie2390
    aggie2390 Member
    TX
    1973 maverick
    i'm going to try and keep my stock mount in tact if i can in case i decide to go back to original later. but thanks for the info!!
  4. Bryant
    im sure you would be able to sell or trade a t5 mount for a stock one if you ever did want to go back.
  5. aggie2390
    aggie2390 Member
    TX
    1973 maverick
    Just finished welding it all up. More pics on the way.
      File size:
      347 KB
  6. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Looks good. Go ahead and make me one too while you are at it. :yup: My welding buddy moved 20 miles away and I'll be tackling my T5 swap pretty soon also. I don't think the crossmember I made for my AOD is going to work with a t5, plus yours looks much nicer. :thumbs2:
  7. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    great job! I like the look. You know, you should make some templates of that or maybe make some because people on the board have been asking for these for a while.
  8. aggie2390
    aggie2390 Member
    TX
    1973 maverick
    thanks! i'm not done yet because i ran into some clearance issues once i'm done with it i'll pose the rest of the pics along with explanations.
  9. aggie2390
    aggie2390 Member
    TX
    1973 maverick
    Here is the final product. Instead of using the stock mount i bolted the member to the actual transmission with some rubber in between. when i first made it the holes for the bolts were right on the edge of the tubing so i cut a slot out of it and welded another section in to off set the middle of the member. Hope y'all like it.
      File size:
      329.7 KB
      134
      File size:
      335.4 KB
      139
      File size:
      326.4 KB
  10. mojo
    I like it. I don't have any plans to go manual trans. but, that's a darn gud lookin piece of work. Those are some great lookin weld beads. Like to see some more of ur work in the future. (y)
  11. Awesome_X
    Awesome_X Member
    Oklahoma
    Indeed what mojo said and that reminds me of how much I suck at welding.
  12. PaulS
    The Welding is good! It looks like a great job - except for one thing...
    What you have is a mount that only gives in the down direction. You need another piece of rubber at the bottom with either big washers or a plate between the rubber and the bolts.
    So the sandwich goes:
    transmission, rubber, crossmember, rubber, plate (or big washers), and then the bolts.
    That way you won't break the transmission tail housing under rough use.
  13. Ryan
    Ryan Ford Addict
    Phoenix Az.
    Like Paul was saying, the transmission needs to TWIST. Have you seen how much your motor twists under a load? The Tail shaft needs to be able to twist on the mount, otherwise you can crack the tailshaft. Just adding to what Paul was saying.
  14. aggie2390
    aggie2390 Member
    TX
    1973 maverick
    Thanks i'll definitely take a look at that. Thanks for the input!
  15. Derek 5oComet
    Derek 5oComet Tire burner
    Welland,Ontario,Canada
    Here's the one i made.
