T5 headers
Discussion in 'Technical' started by BossMaverick87, Sep 15, 2012.
  1. BossMaverick87
    BossMaverick87 Member
    California
    Maverick with cougar taillights
    Did a search, but it was difficult to find any information.
    I am rebuilding my Maverick's 302 and want to add headers. I was thinking of Doug Thorley headers and have the link provided below. And being that my car has a T5 5-speed, there is a chance they will not fit because the application claims it "fits column shift models only". Has anyone had experience with these headers? Can anyone else give me a suggestion to a good set of long tube headers assuming these do not fit without modification? Thanks
    http://www.summitracing.com/parts/DTE-268-C/
    Edit: No A/C, no P/S, manual transmission, floor shifter. I know the application says it will fit, but Summit techs don't specialize in making them, they only sell them. Does anyone have experience using them?
  2. Craig Selvey
    I have Doug Thorley headers on my car...but it is an Automatic.
  3. injectedmav
    injectedmav Member
    Georgia
    Are you using a cable clutch, hydraulic conversion or stock maverick bell crank?
  4. Steven Harris
    Steven Harris Member
    We used the Hooker set: EFI with T-5 cable clutch. The cable runs close and needs to be anchored away from the tubes.
  5. BossMaverick87
    California
    I'm using mechanical linkage. I modified my bellhousing to support a pivot ball and a new clutch fork so it would push the fork to disengage the clutch
  6. Falcenac
    Falcenac Member
    Sechelt B.C. Canada
    1969.5 Maverick 71 Comet G.T. 76 Comet 4 door 61 Falcon x2 60 Frontenac
    I have the same clutch set up as you with a t5 and hooker comp long tube headers it is tight to linkage and pitman arm but does work well have no real issues clutch linkage does slightly touch pitman arm on a tight left turn but not a big deal.
  7. injectedmav
    injectedmav Member
    Georgia
    I'm using hookers part #6901 which I think they offer in ceramic coated as well. The tubing is a little thinner I think than the Doug Thorley's but they'll last years with that coating. I use a 86-93 bell housing and like Steven Harris, I had to wrap the cable and anchor it to prevent contact with the tube. If you're using a modified old style bell housing, it might be considerably different.
  8. BossMaverick87
    California
    It's going to be until Tuesday before I can get an answer from Doug Thorley regarding header/T5 compatibility since their Maverick guy is on vacation. The hedman elite headers are only for automatic transmissions, and I'd like something a little thicker than the hookers.
