t5 Safty Switch & Reverse lights
Discussion in 'Transmissions' started by 71_Maverick, Sep 27, 2008.
  1. 71_Maverick
    71_Maverick Member
    michigan
    well im looking how to hook up reverse lights and how to bypass the neutral safety switch for converting to a t5. i had a c4 auto in, also is there a clutch safety that i will have to hook up?
  2. Mavaholic
    Look under the dash at the base of the column. The backup light switch is mounted there. Just move the two wires from that switch to the switch on the T5. There is no clutch safety switch to worry about.
  3. PaulS
    No clutch safety switch but if you want one you can use the neutral start wires to run to a switch mounted on the clutch peal or linkage.
