T5 Swap on a Ford Maverick - (Crossmember Bar)
Discussion in 'Technical' started by MaverickLDO, Apr 18, 2025.
  1. MaverickLDO
    MaverickLDO New Member
    Forks
    Maverick
    Hello there.
    I am swaping my engine and transmission on my Ford Maverick. My doubt is will this part (for mustang) work on my Maverick?
    Scott Drake 8 Cylinder T-5 Conversion Part (Crossmember Bar):
    There are two options, Mustang 65-66 and 67-70
    My doub is, will this works on my Maverick or is it just Mustang compatible?
  2. MaverickLDO
    Forks
    Maverick
    Forgot to say it more clearly, it's a 302 engine and a Tremec T5 Transmission.
  3. 71gold
  4. bmcdaniel
    I used the stock V8 crossmember. Turned it around backwards and welded on a "back porch" since the T5 mounting pad is 1-1/2" farther rearward than on the original trans.
  5. Powerband
    Powerband Member
    NY's \H/
    T5 swapped onto 74 / 250 was Toploader 3 OTT'.
    had two six crossmembers - cut , doubled plate and added some reinforcement.
    . [​IMG] .[​IMG] . [​IMG]
    Toploader tranny output DS/ angle was matched with taller T5 and top shifter box accommodated '
    [​IMG].
    [​IMG] . [​IMG] . [​IMG]
    [​IMG].[​IMG]
  6. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Mustang ones will not fit.
