t5 tranny
Discussion in 'Transmissions' started by aguerra186, Feb 4, 2014.
  1. aguerra186
    aguerra186 Member
    San Antonio, TX
    Ford Maverick
    would a v6 t5 tranny fit in my maverick?? or should i get one from a v8 instead?? which one is better??
  2. Acornridgeman
    Wisconsin
    A V6 one will be fine for a mild 302 motor. In fact some of the V6 ones are rated for more torque than some of the V8 ones. Do you have the TAG ID number? We can tell you what it is from.
  3. aguerra186
    aguerra186 Member
    San Antonio, TX
    Ford Maverick
    i already have the t5 but, which adapter should i use if i have a 3speed transmission on a 302 v8?
  4. rthomas771
  5. aguerra186
    aguerra186 Member
    San Antonio, TX
    Ford Maverick
    can i still use the same clutch for the T5 or do i have to replace it?
  6. Krazy Comet
    The V6 trans have a longer input(as do '94 & '95 5.0), so require a deeper bell housing or swap the input shaft...
    Also I believe they are rated same as '86-'89½ 5.0 which was 265ft lb, 5.0 were up graded to 300ft lb rating late in '89... You can bust the 265ft Lb version with a stockish 5.0, got the T-shirt for that one...
    BTW
    Here is the chart to ID the Ford version T-5... The '94 & '95 input shaft are 2/3" longer than '93 earlier 5.0, there were no V6 versions prior to '94...
    http://www.fordmuscle.com/archives/2000/09/t5swap/index2.shtml
  7. garrettmuir1227
    garrettmuir1227 (Almost) Certified to Work on Your Porsche
    Temecula,CA
    1974 Mercury Comet (small bumper Mav converted) 2009 Mustang Bullitt #5834
    i diddnt know this existed when i was mating my tranny so i decided to just get a cable clutch :( now i want this but i dont want to remove my tranny lol
  8. jeremy
    jeremy I build t5's
    Corona, Ca
    all 91+ t5's, including the v6 trannies are ALL rated the same
  9. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    What yr model is your Mav,the early ones have a small trans tunnel which could be a prob. w/ the t5.
  10. Krazy Comet
  11. Falcenac
    Falcenac Member
    Sechelt B.C. Canada
    1969.5 Maverick 71 Comet G.T. 76 Comet 4 door 61 Falcon x2 60 Frontenac
    I have a 69.5 with a t5 swap fits extremely tight to tunnel but does fit. Put one in a 61 Falcon lots of tunnel mods
  12. jeremy
    jeremy I build t5's
    Corona, Ca
    UGH, forgot about the 4 cyl t5's...I usually gut them and build z specs out of them.
    That chart is a little misleading...
    the trans listed motorsport is the t5z..the t5z never came in any production vehicle, so it cannot be included in this discussion, as it was always a catalog only transmission.
    the cobra t5 shared a pocket bearing with the t5z...it does add 10 hp to the rating..
    other than that, the v8 and v6 transmissions are all rated the same after 90. (that chart is wrong).....they didn't use two different gearsets after 90 (with the 4 banger t5 being the obvious exception) (I've been building t5's for over a decade, and it's also common knowledge)
  13. gotstang
    gotstang Member
    woodstock Ontario Canada
    t5
    I been following this post on the T5 conversion. I looked at how rthomas771 did his T5 conversion on His home page I'm doing the same conversion I have two questions for rthomas771 with the 300 rear end gear You said in 5th gear it was fine 2000 RPM at 75 MPH but you are running a 15in tire. would it be worst for me with the 300 rear gear and I have 14 in tire? Or will it still work ok? And also You said You did not have to shorten the drive shaft? Thanks any answer to my questions will be helpful. gotstang
  14. Acornridgeman
    Wisconsin
  15. rthomas771
    The shorter the tire...the lower (higher number) the finial gear ratio. In other words...your car will feel like it has more than a 3.00:1 with a shorter tire than it would if it had a taller tire. You have to be looking at the tire height...not the size of the hole in the center of the tire. Some 15" tires are not as tall as some 14" tires. I have 235 60x15's which are 26.10" tall...a 225 70x14 tire is a smaller tire but it is 26.40" tall. I didn't have to do anything to the driveshaft.
