T5 with stock rear gear ?
Discussion in 'Technical' started by mavgrab302, Jan 7, 2014.
  1. mavgrab302
    Many of you know I have a t5 swap ready to install. The question I have is should I wait until I have a budget for rear gears ? I decoded the tag on my 8" and I have a 279 gear open. I'm worried about how this combo will perform... It is fine with my c4 but how will it be with a t5 ?
  2. 71gold
    drive it until you get the gear you want...:chirp:
  3. groberts101
    groberts101 Member
    Minneapolis, MN
    It'll be much better with the rear gear you have than the C4 ever was.. that's for sure.
    And if you put a big-block up in front of it?.. you'll be better able to pull that massively tall final gear ratio to cruise down the highway at around 100mph while lugging along at just 1,500 rpm too. lol
  4. mavgrab302
  5. groberts101
    groberts101 Member
    Minneapolis, MN
    Holy 9 inch, Batman!
    eerrr.. that sounded bad.. but you get the idea. lol
  6. mavgrab302
    I know its a 65/66 stang housing but it's supposed to bolt right up and is only .75" wider... I can loose my spacers I have now... And it's complete including 11" disc brakes...
  7. rthomas771
    That is not a factory 65-66 Mustang 9" housing. The factory had tapered tubes. Here is a factory 66 9".
  8. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    youd be cruising 70 mph at 1700 rpm which is pretty sweet :)
  9. injectedmav
    injectedmav Member
    Georgia
    I used a stock 3.00:1 gear with my T5 for 7 years before I changed to a lockind diff requiring the change. Got 25 MPG on the highway, 20 around town.
  10. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    thats really tempting me to toss my stock rear end back and get the 4.11's out :bouncy:
  11. Krazy Comet
    If you gave the 3.35 1st gear trans, anything over 3.50s out back limits 1st gear's usage, those were basically designed to be used with 2.73 - 3.08 ratio... A limited slip rear is a necessity, still my T-5 2.73 geared '86 GT would roast the tires any time I got a little heavy footed...
    The 3.50 is a good choice if you have the 2.95 1st gear T-5...
  12. krelboyne
    krelboyne Remember
    Salem, Oregon
    I agree with what is being said. I doubt if you would be able to use 5th gear without lugging the engine until maybe 65mph or higher with the stock gears.
    Remember these T-5's are from cars with fuel injection and computer control. Our older cars with vintage engines and carburetors weren't designed to run at the lower rpm's that modern technology can take advantage of.
  13. rthomas771
    My t-5 is from a 5.0 Mustang, rear ratio is 3.00:1, 225x15 rear tires. I can cruise at 45 mph up a slight upgrade with no problem. Flat ground I'm in 5th gear at 35 mph. Although I have a 6 cylinder with more low rpm torque than a V8. 85 mph is twisting 2,000...70 mph is around 1,600 rpm.
  14. lynhrt210
    lynhrt210 Member
    somewhere
    1974 ford maverick
    What year vehicle is that t5 out of?
  15. rthomas771
    World Class T5 from an '85 Mustang GT
