T5 yoke question
Discussion in 'Transmissions' started by bmxkrisv, Jul 31, 2010.
  1. bmxkrisv
    bmxkrisv Member
    ojai,ca
    70 mav
    so I've got my 302 and my t5 bolted in, my drive drive shaft seems to be functional but I hear t5's need a specific yoke. I'm reusing my original driveshaft (1970 200 I6 w/3 on tree) it splines up and is inserted 5" in the tranny, is that enough to prevent vibrations? I could lengthen the driveshaft aprox 2" to set the yoke deeper if I need to, or do need to buy a new yoke?
  2. baddad457
    As long as you've got about 1" if the yoke sticking out of the tailhousing, you're fine.
  3. 302-72-mav
    302-72-mav Member
    sactown CA
    i am using my stock driveline and no problem at all and i have been over 100 mph good luck
  4. bmxkrisv
    bmxkrisv Member
    ojai,ca
    70 mav
    I guess I'll just have to try it when the time comes(still more work left to do)
