Tach wiring, switched 12v terminal
Discussion in 'Technical' started by yanniz, Apr 6, 2013.
  1. yanniz
    yanniz Member
    Lynnwood WA
    1974 comet
    Hi everyone, new here....I just got a 1974 Mercury Comet and I am trying to wire in a tach...
    In the past, I have had a Chevelle and Camaro (race car) and always done my own work on electrical, engine, et cetera... I am trying to figure out the Ford side of things now....
    The fuse box is located above the dimmer switch on the driver side...it does not have any connection points (Aux, lights, et cetera.)
    Where do I pick up the switched 12v signal for the tac? Also, the coil (all original) has a "battery" and "distributor" terminals....where do I pick up the tach signal?
    Thanks guys...
  2. rthomas771
    The tach will go to the minus (-) on the coil, get you switched power from the radio feed wire
  3. mav1970
    Sweet looking Comet - Welcome to the site :Welcome:
  4. jncastell
    jncastell Member
    Ogden, Utah
    1974 Maverick Grabber Clone
    :Welcome: Nice Comet!
  5. 71gold
    :Welcome:...:Handshake
  6. yanniz
    yanniz Member
    Lynnwood WA
    1974 comet
    thanks guys...
    negative terminal on coil is the one labeled "distributor?" I have always had ignition boxes, digital 6 et cetera, and the tach connection was on the box itself...
  7. rthomas771
    Yep that's correct
