Tail light lens
Discussion in 'General Maverick/Comet' started by SpeedMaven, Oct 13, 2007.
  1. SpeedMaven
    SpeedMaven Mississippi Mad Man
    Gulfport, MS
    1970 Maverick, 1957 Ford Custom Tudor
    Does anyone make lens for Maverick/Pinto tail lights? Mine are in in pretty sorry shape, and I cant find a good set, most are like mine, cracked in the taillight and backup lens. Help me out, I need 2 pair.
  2. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    Someone here will sure fix you up with a nice set.
    Dan
  3. scooper77515
    I was thinking about this today...I have bobcat tails which are even HARDER to replace.
    I wonder if I could buy an aftermarket chevy replacement, maybe from a camaro or something, and use my dremel tool to grind the lens down to fit?:hmmm:
  4. Craig Selvey
    I have tons of them. Email me directly (see below) if I can help.
  5. Jamie Miles
    The outside lenses in the Bobcat lights are the same as the Maverick/Pinto lenses. For the inside, you can cut the reverse light off a Maverick lens. For example, you would take a left side Maverick/Pinto lens, cut the reverse light section off, and put it in the inside of the right side Bobcat light, and vice versa. It would not be exactly the same as the original inside Bobcat lenses, but only the most discriminating eye would notice the difference.
  6. SpeedMaven
    Gulfport, MS
    That's why I need 2 pair (y)
