Tail light trim
Discussion in 'General Maverick/Comet' started by wolfheads, Jan 31, 2016.
  1. wolfheads
    wolfheads MadMav
    Florida
    73 Maverick / 2000 Harley Low Rider
    Is the tail light trim on a maverick aluminum or stainless steel? Either way, what's the best way to polish them to a mirror finish?
    Thanks
  2. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Simichrome is a great polish for that. Used to polish molds to mirror finish
  3. Acornridgeman
    Wisconsin
    It is an anodized aluminum. I use a paste product called FLITZ. The rear window trim and the headlight bezels are also the anodized aluminum. Use a cloth as 0000 steel wool will cut through the anodizing if you are not real gentle with it.
    Cruzin Illusion likes this.
  4. wolfheads
    wolfheads MadMav
    Florida
    Thanks guys.
  5. 71gold
    there is a U tube vid for using drain cleaner to remove the anodized coating. I think Jeff has a write up on it...I've never had any luck polishing the trim, I glassbeaded and painted mine.
  6. groberts101
    groberts101 Member
    Minneapolis, MN
    You can't completely polish away the damaged anodized areas so if the trim is in rougher shape.. that's the best way to do it to get to an original baseline to work off. Then you need lots of water, ultra-fine wet sandpaper, and lots of elbow grease. Buff it out in a couple of stages and you're golden. errr.. silver. lol
    VERY time consuming and I hate it more than polishing intake manifolds. Love the final results though. To stay nice and shiny it needs to be reanodized, clear gloss powdercoated(they need to be more careful with thin aluminum trim in the oven) or protected with sealants and maintained. Please keep in mind that painted clear-coats will NOT adhere over the longterm due to insufficient mechanical bonding when applied over a highly polished surface.
    Acornridgeman likes this.
