taurus fan diode wiring?
Discussion in 'Technical' started by xpsnake, Jul 4, 2009.
  1. xpsnake
    xpsnake Bruce
    Maryville, IL (near STL)
    1971 Ford Maverick 2-door
    I'm going to install a taurus fan on my fancy new aluminum radiator (copper one finally gave up the ghost). I'm using the attached schematic to wire it. However, I want to avoid the AC voltage spike when the fan spins down, so I need to wire a diode in somewhere. I'm not entirely sure where these bad boys need to be located. I'm going to use a 1N5404 diode as suggested in the diagram, but will placing it along ONLY the ignition circuit protect my electrical system or should I use two diodes, one on each switched feed to the fan to totally isolate it from backfeed?
    ...or should I use find some relays with built-in coil diodes... or diode each coil?
    So confusing..
  2. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    You don't need the diode where they say. I think you need two where I've indicated. They keep the reverse dc voltage from back feeding into your system. I would also find relays with a built in resistor, that way it doesn't matter which way you hook up the coils and it will do the same thing as the diode. I think most automotive relays have them built in
  3. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Where did you find this wiring diagram?????????
    Jay
  4. 71gold
    Jay, do you have a... diode...in your fan wireing?
    ...Frank...
  5. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    this is the one i got from here somewhere.
  6. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    Frank
    I due but not in the fan wiring .. Mine is in the wiring for the alternator it's on the trigger wire for the regulator from the ingnitions switch ..
    Jay
    I think it may not be a bad idea ..
  7. bradleygt
    bradleygt Member
    grand rapids michigan
    1970 maverick
    do you need five relays to run a fan:huh:
    wow
    brad:)
  8. 71gold
    mine is wired like the top of the pic. only diff. i have a temp. sensor in the intake, inline with the ground wire....185 on 170 off...
    :drive:
  9. xpsnake
    xpsnake Bruce
    Well, one for each fan speed. One for switching between the two in an "automated" circuit. One for A/C switching, which I'm not using. And the 5th is for a tri-color LED on the dash that indicates the state of the fan (Green = low, Red = high, Blue = A/C)
  10. xpsnake
    xpsnake Bruce
    I was under the impression it was an AC generation, which is the danger in a DC system.
    Been a while since I took electronics, but I should be able to just piggyback the diodes into each line and ground them out, which won't matter until the juice is turned off, which "energizes" the diode and grounds the circuit, correct?
  11. fastback86
    FL
    If the motor is like a relay there is a voltage spike when it is switched off. The voltage spike is from the magnetic field collapsing across the coil and inducing a voltage. Your ignition coil fires the same way, producing a spark when the coil is switched off. In a relay the spike is always reverse in polarity, which would put a clamping diode in forward bias shorting the spike.
    I think the fan motors are permanent magnet motors which may act like a generator when spinning down. But then again they are controlled by a relay, so if the relay switches open there really is no place for the power to go, except maybe to prevent the contacts from burning as they open.
  12. Mavaholic
    Looks to me like its just used to keep from energizing circuits that you may not want energized. IN other words, you dont back feed 12v to the accessory side from the ignition side.
  13. xpsnake
    xpsnake Bruce
    Anyone got a source on 12V diodes... and precisely how to wire them into my circuit?
  14. fastback86
    FL
