Taurus fan Volvo controller wiring
Discussion in 'Technical' started by jasonwthompson, Oct 14, 2016.
  1. jasonwthompson
    jasonwthompson Member
    Carrollton TX
    Since we are now ready to hook up the Taurus/Volvo/BMW fan modification, I have been looking more closely at the wiring setup. It looks as if many have the main controller power coming straight off the battery with a high amp fuse attached. Wired in that manner won't the fan possibly stay on after the car is shut down? Does anyone here have theirs wired this way, and if so has there ever been problems with the fan exhausting the battery?
  2. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    I wired mine this way but added a relay to the ground side of the sensor. You are correct. The fan would run until the temperature dropped after car was turned off.
    jasonwthompson likes this.
  3. 71gold
    I wired my Volvo relay to...switched on 12V...
  4. jasonwthompson
    Carrollton TX
    Thanks guys, I believe we will mimic one of your setups, either an additional relay or switched power. I just wanted to confirm that my limited electrical knowledge was correct in my assumptions.
  5. bmcdaniel
    Mine's connected to the battery and runs on low until it cools down. It cycles on and off 4 or 5 times and then it's done.
  6. 71gold
    even with switched power it needs to go to a relay...:yup:
