TC To flywheel problems.
Discussion in 'General Maverick/Comet' started by satchelmcqueen, Apr 5, 2019.
  1. satchelmcqueen
    satchelmcqueen Member
    rome georgia
    Ok guys, where did I mess up? The flywheel I ordered is a 28oz 157 tooth for this 302. It measures the exact size and tooth count as the 250 flywheel.
    The problem is, I cannot get the 250 TC converter to mount to it. Not only is the flywheel to thick to even get the TC studs to pass through, but the holes in the flywheel dont even match the TC converter studs.
    What do I need to do? Pic attached.
  2. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
    You have a flywheel for a manual bolted to the engine???
    satchelmcqueen and Krazy Comet like this.
  3. Krazy Comet
    LOL, you want a C4, 157T, FLEXPLATE.
  4. satchelmcqueen
    rome georgia
    See I always thought "flex plate" was the same as a flywheel. Now I see its not. I feel like an idiot lol. Now I know.
    So before I mess up again. The trans is out of a 72 maverick...250. So I need to order a flex plate for a 302 157 tooth correct? And this will ensure the 250 converter will bolt up? Thanks and I now think ill go drink some beer. Was really wanting to get this together tonight lol
  5. satchelmcqueen
    rome georgia
    I didnt know there was a difference. Now I know. Uugggg!
  6. Krazy Comet
    satchelmcqueen likes this.
  7. rthomas771
    rthomas771 Member Supporting Member
    '74 Maverick 250 5-Speed.'60 Falcon V8 Toploader 9". '66 Falcon Sports Coupe, '63 Falcon Sports Coupe
    You need a 250 flex plate with a 250 engine...or 302 flex plate with a 302. The 250 is internal balanced so the flex plate is zero imbalance, the 302 is external balanced and has a 28 oz imbalance flex plate.
  8. dyent
    dyent Member
    vancouver bc
    You can always take both Flywheel and Flex Plate to a machine shop and they can rebalance your 250 Flex Plate to match your 28oz Flywheel, they need both so to make sure weight is correctly matched to bolt pattern. As you are aware, Flywheel/Flex Plate bolt pattern is matched to crank, so can only go on one way...........
    Do not know if cheaper to buy new/used Flex Plate or rebalance, but at least you have couple of options.
    David
  9. yellow75
    Tillamook Oregon
    72 Maverick 64 Falcon 2 door wagon 1976 Maverick Stallion 2007 Shelby GT 500 2019 Ford F150 FX4
    Well it looks like you have the correct motor plate for an automatic at least. Just get the right stuff for your installation maybe get a slightly higher than stock rpm torque converter. Put some thread sealant on the bolts that hold the flex plate on as to avoid an oil leak .
  10. satchelmcqueen
    rome georgia
    Thanks all. I found a new one from jegs for $65. 28oz and 157t.
    Pulling motor and trans out of my 70 right now getting it all clear. Maybe later this week I can get this in.
