TCP Coilover Info
Discussion in 'Technical' started by 71maverick361, Mar 23, 2016.
  1. 71maverick361
    71maverick361 Vern Isaac
    Odem
    71 Grabber
    Ok considering purchasing the Total Control Front Coilover suspension. I have read all the threads on here and still wondering??
    1/What's the best spring choice as they offer several for daily driving and some drag strip
    2/How much adjustability do the Coilover have as far as up and down for ride height
    3/How important is having adjustability on shock compression and rebound
    4/ OP reviews
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Why??
  3. 71Mavrk
    71Mavrk Member
    Nevada
    I have 3,200 on my set up. I have no complaints and the car handles excellent.
    I have 500# spring on an aluminum head engine, AOD and AC. A bit stiff but I like it.
    I have not played much with the ride height. I believe you want the lower arms parallel to the ground. Mine sits pretty low and I might see if I can bring it up a bit.
    As far as the shocks. I have not found the time to play with it either. The level of adjustability would depend upon what you want to do with the car.
    Micah
    Crazy Larry likes this.
  4. 71maverick361
    Odem
    71 Grabber
    Thanks Micah
  5. 71Mavrk
    71Mavrk Member
    Nevada
    Sure, there are pictures in my Showcase post if you want to see what it looks like.
    Micah
  6. 71maverick361
    Odem
    71 Grabber
    Nice I will check them out
  7. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    I agree with Larry, why? Knowing what you have accomplished with your build you obviously have a good head about you when it comes to cars and no doubt your advice would be sound. Share some knowledge man, enlighten us!!!!:beerchug:
  8. RMiller
    Kennewick, WA
    Invalid advice without reason.
    mojo and Crazy Larry like this.
  9. RMiller
    Kennewick, WA
    Got it.
  10. 71maverick361
    Odem
    71 Grabber
    Anybody else have this setup?
  11. 71maverick361
    Odem
    71 Grabber
    Ok pulled the trigger for a guy with a brand new in the box coil over fronts with spindles and got it for $2186 shipped to me :thumbs2:
  12. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    That's awesome. Let us know how it goes.
  13. 71maverick361
    Odem
    71 Grabber
    I will post it up when I do the install and the Wilwood brakes
  14. 71Mavrk
    71Mavrk Member
    Nevada
    Install is not too difficult. Probably the hardest thing is drilling out the spot welds on the upper coil mount.
    I used the original spindels. This is also what Wilwood specified.
    Did you get the "Shelby Drop" version?
    The Wilwoods were also an easy install. I got their stainless braided line it. The only thing I had to do was get a 90* fitting at the caliper to get the line out of the suspension. I had to specal order it from a local fittings shop.
    Micah
  15. 71maverick361
    Odem
    71 Grabber
    Yes they are the Shelby drop . Yeah I had a line maker make me the lines and he included them 90degree fittings
