Temp Gauge
Discussion in 'Technical' started by Scotty P, May 26, 2007.
  1. Scotty P
    Scotty P Member
    santa rosa, ca
    Srange thing happened tonigh. After about mins of running my water temp gauge went to 290*. I KNO the motor was not that hot. Sound like a ground issue?
  2. hotrod-daddy
    hotrod-daddy Member
    Rock Springs,Wyoming
    a 1971 Grabber with a 302/351
    It could be........If it checks out OK,re-check your timing
  3. PaulS
    Unless your thermostat is stuck or in backwards.
    Did you put Teflon tape on the sender? that can cause grounding problems. Do your other gauges work ok? If not it could be the voltage regulator under the dash for gauge supply voltage.
  4. hotrod-daddy
    hotrod-daddy Member
    I have seen too much teflon tape on a number of jobs. I like to use the liquid teflon.......much better (y)
  5. Scotty P
    Scotty P Member
    santa rosa, ca
    Thermostat is fine, problem just started. No teflon tape used (no leaks either) Not the timng, ven way off tming would not let a car get that hot that fast. I truly believe that the gauge is reading inaccuratley that is why I was assuming a bad ground or somethng. I will pull the wiring today and check. Thanks for the ideas. Scott
  6. Dan Starnes
    Dan Starnes Original owner
    West Central IL
    I just had something like that happen to me,, was an air pocket in the cooling system, I bled it off and now is fine.
    Dan
  7. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    agree......we put fluid in PINKY II and after firing she almost instantly shot to the moon.....o_O was just a little air pocket. :Woot:
  8. Scotty P
    Scotty P Member
    santa rosa, ca
    Bad ground was the culprit. Back to 190*.
  9. Dan Starnes
    West Central IL
    Glad it was that easy.
    Dan
  10. hotrod-daddy
    hotrod-daddy Member
    Glad you got it fixed !!!!!
  11. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    (y) good job!
    electrical gremlins can be such PITA's :yup:
