Temp guage
Discussion in 'Technical' started by danny, Jan 21, 2005.
  1. danny
    danny Member
    donna, Tx
    77 maverick
    HI,
    I need to added a temp gauge to my 77 mave but dont know how to hook up everything and what type of temp guage i need? IT has a 302 V8.
    Danny
  2. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    Danny-
    If you buy an aftermarket gauge from a Pepboys or Summit etc.
    It should come with directions. They come in electric and mechanical.
    If mechanical, it will have (most likely) a hard brass or metal line that
    needs to have a fitting going into a water jacket in the intake.
    Try www.summitracing.com
    Seth
  3. danny
    danny Member
    donna, Tx
    77 maverick
    Would the electric be better cause i put everything electrical under the hood??
    -Danny
  4. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    I would go with mechanical....some opinions would vary....people worry about developing a leak inside the car due to the hose/line that runs from the intake....but my choice would be mechanical.
  5. danny
    danny Member
    donna, Tx
    77 maverick
    Mechanical gauge
    Were could i get a mechanical tem gauge and how would i install it:confused:. Iam new at this stuff and don't know to much about cars.
  6. Grabber5.0
    Grabber5.0 Gear-head wannabe
    Kansas City, MO
    71 Grabber
    Any parts store will have them. Just remove the stock temp sender for the idiot light from the intake and screw in the right size adapter (they come with the gauge), then put the sensor and tighten the nut. All this of course AFTER running the line through the firewall... ;)
  7. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    not sure on a stock intake, but here is were mine is mounted on my Super Victor :D
  8. danny
    danny Member
    donna, Tx
    77 maverick
    Thanks
    Thanks for the info guys:D.
    Hey what kind of carbuater do you have on your 302
    I was thinking of get a 4 barrael but don't know if i have to do any mod. The reason i ask is cause when i tryied to buy a carb the guys form autozone told me they ran at $113 & up but told me i had to know the number:confused:. I bought the car just the shell and it doesn't have any sticker for the carb it uses. I just want something that will give me some house power on a tight budet:D
    Danny
  9. PINKY
    Louisville, Ky.
    1970 Ford Maverick
    really need some motor specs......the number he is refering to (I believe) would be the cfm.....and that depends on (mainly) your motor.
    For a general rule of thumb, you can use this formula:
    C.I. (cubic inch, motor size)
    x rpm
    /3456
    That number will be @ 100% efficiency
    Most street cars only run at about 80% efficiency. Hard core racer at about 95%.
    example:
    x 6,000
    1812000/3456= 525 cfm.
    again, just a general formula...not LAW
