Temp sending unit
Discussion in 'Technical' started by streetrod77, Jan 31, 2006.
  1. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    I want to put in an AutoMeter Electric Temp Gauge. It comes with a sender. Do I put that sender in the same location? Or can I use the factory wire & sender & connect it to the AutoMeter gauge? One other thing is can I use the same hot wire on more than one gauge?
  2. RegL404
    RegL404 Member
    Most, if not all the time, you will need to use the sender that comes with the gauge. I would run a new wire from the new sender to the new gauge. Yes, you can use one hot wire to power more than one gauge.
  3. streetrod77
    streetrod77 Member
    Memphis,Tenn
    77 comet
    Thanks RegL404
