temperture gauge
Discussion in 'Technical' started by JHodges, Jun 27, 2007.
  1. JHodges
    JHodges thumper
    Dora Alabama
    at advance auto parts they have a mecanical temperture guage made by sunco and it is around $17 and I was wondering if it would work on my maverick which has a 250 6 cylinder
  2. Craig Selvey
    I don't see why not. It will have all the adaptors in the kit to mount the sensor in the head.
  3. Jamie Miles
    Alto, GA
    I've had a few
    It will work fine. We have one on the '72.
  4. 20cows
    20cows Member
    West Texas
    74 Maverick
    I just put one on a 74 with good results.
  5. JHodges
    JHodges thumper
    Dora Alabama
    about how long does it take to install
  6. stmanser
    Davenport, Iowa
    i have the Sunco Tri Gauge kit... chrome.. mounted under the dash.. works awesome.
    mechanical oil gauge with copper line, mechanical temp gauge, and a voltmeter
  7. Jamie Miles
    Alto, GA
    I've had a few
    I would estimate around 30 minutes if it's your first time doing it. Have some more antifreeze on hand, because you will loose some when you unscrew the temp sending unit out of the back of the head.
  8. 20cows
    20cows Member
    West Texas
    74 Maverick
    ...unless you put a pan under the drain and drop the fluid level a bit first. Of course, then you have to pour it back in.:rolleyes:
  9. Jamie Miles
    Alto, GA
    I've had a few
    It is easier in my opinion to just remove the sending unit without draining the excess coolant. If you have the temperature probe of the gauge ready to screw in, you will loose coolant for all of about 5 seconds. Then if you loose enough to actually matter, you can just top it off. But that's just my opinion. Of course you probably wouldn't want the antifreeze draining all over the place on a pristine show car. But on my grimey daily driver, a little antifreeze is no big deal.
  10. JHodges
    JHodges thumper
    Dora Alabama
    I bought it about a month ago but have never installed it.
  11. Maverick73
    Maverick73 Senior Member
    Lakeland, FL
    I have one on my '73. Looks and works fine.
  12. T.L.
    T.L. Banned
    Southern Colorado
    '73 Maverick 2-door, V-8
    'Depends on how fast you move...
  13. PaulS
    With my bad back, and my advanced age it might take the better part of an afternoon to get the job done. A few years ago it would have taken an hour to do it and make it look real nice.
  14. 20cows
    20cows Member
    West Texas
    74 Maverick
    I put the three-gauge cluster in the '74.
    Ignorance was bliss. Then I found out how low the oil pressure really was.
    :yikes:
