thanks for the help shock towers are cut
Discussion in 'General Maverick/Comet' started by billrogers, Mar 5, 2013.
  1. billrogers
    billrogers Member
    hudson falls ny
    70 maverick
    i got my shock towers cut and welded back up last nite waiting on my headers and stall converter from summit now should be here today cant wait to get the motor in is there any thing more i should do to be preped before i set the 351w in thanks for talking me in to notching the towers
  2. billrogers
    billrogers Member
    hudson falls ny
    70 maverick
    some pics of my shock towers gonna have the 351 in tomorrow nite
  3. 71gold
    in the 4th. pic, is there any reason the center at the bottom can't be cut at a 45 degree angle?
  4. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I really wish i would have done this to mine. the next time the motor comes out it will be done.
  5. RASelkirk
    RASelkirk Retired!
    Port Neches, TX
    Only thing I could see would be the layout, cut, and fit-up would be much more difficult at 45° vs 90°...
  6. super sonic mav
    super sonic mav Member
    Zimmerman,Mn.
    1976 Maverick Stallion
    I will be doing this mod to my Stallion....351 here I come...Thanks for sharing the pics...:thumbs2:
  7. billrogers
    billrogers Member
    hudson falls ny
    70 maverick
    351 sitting in the hole with headers installed
  8. MSmithPDX
    MSmithPDX Member
    Portland, OR
    Man, I've only got a 302 but every time I see pics like these, I want to cut my shock towers...
    Looks nice, I am clearly jealous of your talent.
  9. maverickmadness
    maverickmadness Member
    ala
    1973 maverick grabber, 1972 maverick grabber,1974 maverick grabber,
    what headers are you useing?
  10. billrogers
    billrogers Member
    hudson falls ny
    70 maverick
    sum-g9031 i had to dent drivers side floor a little for one tube hit
  11. maverickmadness
    ala
    thanks for info
  12. dyent
    dyent Member
    vancouver bc
    Looks like you did a great job, nice and clean! When I still had my 74 Comet, since it was a factory 302 car, the shock towers had a extra reinforce plate which wrapped right around the towers, it was about 4" high, so one would have to cut this out too. I believe this reinforce plate was on all 302 from 73 and up, I have seen them on some 250's but I don't know if 72 and earlier had them. What I was going to say for those of you that have 302's, I had mine stoked out to 347, so did not have to worry about header clearance issues as with 351. I used Eagle Gold Label 14 gauge headers at the time and had to modify one tube on the drivers side to clear the manual pitman arm, but other than that everything was fine. The stoked 347 with aftermarket aluminum heads was dyno'd at 380HP with .500" hydraulic cam, this was way back in 1990.......with todays technology, that same stoked 302/347 can make
    close to 500 and still be streetable. So for those of you who rather not cut up their shock towers, this is just another option to think about. For header fitment, Hooker's
    Competition are still the best, you pay more, but for a good reason. I have their 6901-2HKR which are Stainless Steel 16 ga. they will last almost forever and are even polished! Anyways, just thought I would pass on some info that might help......Cheers!
    the 73 Comet which I now have, is a factory 302 and has this same reinforce plate around the shock towers too.
