The Super-Duper Brake weight info thread!
Discussion in 'Technical' started by okibono, Aug 3, 2005.
  1. okibono
    okibono Member
    cali
    Alright, we know that there are a few types of brakes for out Mav's. We have 4 lug drums, 5 lug drums, Mav disc's, Granada disc's, and aftermarket disc's.
    Please share what you believe is the weight of your assembly, why you like it, and why you dislike it.
    I'm trying to figure out how much heavier (if any), the Mav disc brake assembly is compared to the drum brake assembly, and where do the aftermarked kits fit in when its time to weigh in.
    Thanks! (y)
  2. Jamie Miles
    Don't even mess with drums. Thats all I gotta say here. I'm sick of my drums fadeing out every time I get in the littlest bit of traffic.
  3. Comet-73
    Comet-73 Member
    lethbridge AB Canada
    73 comet gt, 76 comet 4 door, 71 Maverick 200/I6
    I have later model maverick disk brakes on my 73 and lincoln rear end with disk in the back the differnce is so differn't it is almost uncomparable weight wise the isnt probable a huge differnce maybe 5 to 10 pounds a piece almost EVERY asspect of braking is better with disks only i would be sure to use new things like calipers, pads, rotors, lines, and ball joints when you do this because this what makes your car stop sure maybe your car can go but will it stop and the ball joints you should replace because your going to need a wheel alinement anyways when you swap the spindles the only thing i found about disk is that the require maintence more ofter then drums you have to replace the pads sooner and the squel a bit more.
  4. stmanser
    Davenport, Iowa
    i would agree with jamie......in traffic.....especially the heat of the day......brake fades getting hair raising....epecially when you know the brakes are good...but the car wont slow down fast enough...lol
    disks all the way...when i can afford it...i am definetly getting front disks at least...
  5. bmcdaniel
    "I have later model maverick disk brakes on my 73 and lincoln rear end with disk in the back the differnce is so differn't it is almost uncomparable weight wise the isnt probable a huge differnce maybe 5 to 10 pounds a piece almost EVERY asspect of braking is better with disks only i would be sure to use new things like calipers, pads, rotors, lines, and ball joints when you do this because this what makes your car stop sure maybe your car can go but will it stop and the ball joints you should replace because your going to need a wheel alinement anyways when you swap the spindles the only thing i found about disk is that the require maintence more ofter then drums you have to replace the pads sooner and the squel a bit more."
    That's gotta be the longest sentence I've ever seen! :90:
  6. Jamie Miles
    I was gonna say, I about ran outa breath after reading that one. :)
  7. Tylar Miles
    Tylar Miles Try try try let it ride..
    Lawrenceville, ga
    1993 Nissan Sentra
    Yep *hits invisible passenger side brake pedal*:biglaugh:
  8. Maverick Man
    California
    Octavian i weighted the stock maverick drum spindels against a set of early mustang drum spindels i was telling you about.. the stock maverick ones are about 1lbs or so the mustang ones are just a tad under that.
    as for the whole ganada set up spindel, nuts, bolts, pads and everything its about 46lbs. where as the stock maverick drums set up are about 44lbs... not much differance.. but they are lighter.
  9. okibono
    okibono Member
    cali
    Cool info! Thanks ya'll! I think I know which way I'm going on this one...
  10. riporter
    riporter Member
    Charleston S.C.
    I went with some of the aftermarket rotors being sold on E-bay, granada spindles and the rest of the hardware from Napa on the front, I couldn't tell any weight difference.
    I didn't change the master cylinder and I didn't add a proportionong valve...I just bled em and go and they work great.
    I have oversize drums on the rear (9"out of an 79 F-150) that make a very big difference also.
  11. okibono
    okibono Member
    cali
    Yeah, I think I'm gonna go with some aftermarked (Wilwood, Aerospace, Strange) lightweight disc's...Even though this car will see very limited street duty, it will still be a street car, and have a small tire. Which means I need all of the weight off of the front as possible...
    Oh, and I guess you gotta slow down after a 135+mph pass, too! So the additional stopping power will be nice...
  12. RabidCustoms
    I'm guessing your talking front brakes?
    the complete set up on my 72 is 32.5 lbs,rotors,calipers,hubs,pads,ect. (aftermarket)
  13. okibono
    okibono Member
    cali
    What type of setup is that, RadMav?
  14. Maverick Man
    California
  15. okibono
    okibono Member
    cali
    Thats old news, baby!!!
    LOL, thats who I got it from....:lolup:
    In fact, check the new thread I'm about to post...(y)
    Email me when you get a chance, Mr. Man...
    Thanks!
