This can't be good
Discussion in 'General Maverick/Comet' started by D-Man, Dec 29, 2013.
  1. D-Man
    D-Man Member Supporting Member
    Texas
    75 Comet
    Opened up the radiator on my 250 this morning and found a milkshake. I'm guessing a head gasket let go? :hmmm:
  2. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Definitely a sight you don't want to see.....
  3. mav1970
    Not good at all :cry:
    Definitely oil in the water - a head gasket is usual where they need to be separated by a good solid gasket :16suspect
  4. Bryant
    your crank case should look like that also. if the dip stick and the oil fill cap come out normal then look at the transmission cooler.
  5. mav1970
    But keep in mind that the engine oil pressure is much greater than the water system pressure. 40 pounds vs a 7 pound cap - with a bad seal between the 2 fluids, the 40 pounds usually pushes it's way into the 7 pounds - I've seen it in the water and not the oil and it still be a head gasket :)
  6. D-Man
    Texas
    75 Comet
    The oil dipstick shows no sign of the milkey stuff. The transmission stick is milkey though. Does that rule out the head gasket or should I drain the oil and look for water? Not that it makes any difference against 40# but my radiator cap is a 13#.
  7. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    Could be the internal trans cooler of the radiator leaking.
  8. blugene
    This is my guess. I see a slight redness to the milky stuff..
    You say you see it on the trans dip stick so that says alot. May need to have the trans flushed and hope it's not too late.. along with replace the radiator and flush the cooling system etc..
  9. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    It isnt a headgasket. It would be muchhhh darker. Like the image below.
  10. Pony Express
    Pony Express Haul'in @**
    DelMarVa
    1976 Maverick
    Cracked head or block?
  11. m in sc
    m in sc Member
    rock hill sc
    This^ seems like the culprit.
  12. mav1970
    Makes sense knowing the trans oil look somewhat the same :)
  13. Bryant
    replacing the radiator and changing the trans fluid is a much easier, cheaper job than a head gasket.
  14. darren
    Ewww. Looks like tranny cooler issue. IF antifreeze got in the trans youve got a big problem.
  15. D-Man
    Texas
    75 Comet
    Ordered a new shiney aluminum radiator today and a transmission pan with a drain plug. Should I take it to a shop to have the fluid exchanged or just change it in my garage? Many thanks to those who have replied.:thumbs2:
