this is prob a really dumb question buuuuttt
Discussion in 'Cosmetic' started by Maverick Hunter, Oct 20, 2009.
  1. Maverick Hunter
    Maverick Hunter Member
    St. Louis
    1974 Maverick Sedan
    is there an easy way to take the trim off the side of my 74 mav?:huh:
  2. will8069
    will8069 Member
    Garland, TX
    1974 Comet 250 straight 6
    Permanently or temporarily?
  3. Maverick Hunter
    St. Louis
    1974 Maverick Sedan
    haha permanently its the really thick kind with vinyl on it..
  4. indyman13
    indyman13 Member
    Little Rock, Arkansas
    Wait a minute-------I had a brain fart on removing the trim when I said pop it off with a putty knife. The emblems work that way. For the trim, there's a nut on the backside of them. The putty knife thing won't work. agggggggggggh!
    I'd be interested in the driver's fender piece if it's in good shape when you get it off. The kind that goes on an LDO like in the pic. (other side though)
  5. indyman13
    indyman13 Member
    don't use putty knife. I got crossed up. The trim is held on with small nuts. You can access them from the fenders, but for the door trim you'll have to take off the interior door panel.
  6. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    No the doors only have the nuts on the very ends the middle is held on with plastic clips that are held on by studs that are welded too the door, those just need to be ground flush. They use the same thing right above the wheel wells. Otherwise you need to unbolt the trim to remove it.
