Throttle cable needed . . .
Discussion in 'Technical' started by mashori, Jan 18, 2010.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
  2. Dave B
    I used the Lokar universal one.
  3. mean_maverick
    i have some. pm me if interested
  4. Matterick
    Matterick Matt Somerville
    Lake Stevens WA
    i used the Lokar. works great and looks nice :yup:
  5. rthomas771
    I have the same Spectre on my Falcon. You will need a bracket to make that part fit/work
  6. Bryant
    i have the lokar also. that one looks alot like the lokar and it should work just fine.
  7. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    there are several sizes lokar has, which size do I need?
  8. Bryant
    it can be cut down if you get one to long. also consider that you may need a longer one for you supercharger. mine is long enough to goto a throttlebody on a efi manifold if i wanted. it makes a nice clean loop right out of the fire wall. i would suspect that 15" would work for you.
  9. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    I've got the Spectre one and I like it. Braided steel, teflon lined, lets me use a much lighter return spring. As rthomas771 said, you do need a bracket. I got both at Autozone.
  10. 302-72-mav
    302-72-mav Member
    sactown CA
    i just went to pick n pull and used one off some other car that looked like the mavs
  11. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    i meant to post an update. so Bryant helped me fix it. basically the hold down bracket was sitting pretty low after the nitrous plate went in. So we put in some spacers (nuts I should say) and the whole thing is working beautifully now
  12. sierra grabber
    sierra grabber Certifiable
    northern nevada
    everyone else seems to have good luck with these? do a search though and you will find i was not so lucky. the solid ends on both the lokar and spectre models broke off on my while driving down the freeway with very little mileage. dont know if i have my return spring too strong or too heavy of a foot? after i bought the third one i modified the solid end to be hex bolted on like the other end and have been much happier with that. just my .02
  13. dkstuck
    dkstuck Member
    Latrobe Pa (Pgh)
    72 Maverick in drag
    sierra, sounds like cable needs adjusted. When carb is fully open, pedal should be just touching floor or some kinda stop.
