Timing chain cover problem!!
Discussion in 'Technical' started by fordmaverick72, Jul 16, 2009.
  1. fordmaverick72
    fordmaverick72 Member
    Milwaukee, wisconsin
    1972 ford maverick 302 30over aod with 8.8
    72' Mav. 250 straight 6.
    removed front of motor pump and cover etc.timing chain was way too loose. needed to be repaced bad i could see feal the damage and how loose it was when i moved the timing chain cover out 2 inches. and thats the problem it only moves 2 inches.the cover due to how it is shaped has to be moved straight out away from the motor. can not be removed by pulling up on the cover.thus my problem is the gear for center pulley sits 3 inches to high for me to pull the cover off(top half of gear obstructing).and seems to run thru the block do i have to lift the motor and drop the lower end to get clearance? are there clips inside the oil pan area where i can un clip this timing cover? Thanks for you help!!!!
  2. darren
    Sorry I'm a bit confused. The pulley your referring to is the Crank pulley?? If so it has to be removed off the crank before removing timing cover.
  3. sierra grabber
    sierra grabber Certifiable
    northern nevada
    it has four bolts holding to the oil pan and is around the pulley. both have to be removed first...
  4. fordmaverick72
    yeah crank pulley is what it is. and for the second comment yeah i figured as much i got the 4 bolts on the oil pan off so it moves a inch or 2 but loookin at it now,it wont come off cause of the ring around the crank pulley. this blows.such an easy part to do.well it seemed that way.atleast these cars are easy to work on.i dont have to take the entire motor and tranny out to do this.il just lift it a foot and drop everything on the buttom till i get to it. thanks for your time.
  5. rthomas771
    You will need a harmonic balancer puller to remove the harmonic balancer. You need to keep the engine from turning when removing the bolt from the crankshaft. You MIGHT be able to get to the harmonic balancer after you remove the grille and radiator.
  6. fordmaverick72
    the rubber that sits between the pulley and gearwheel has broken apart in the process of me messing around with the timing cover.any help with how much trouble ive got myself into taking that off? i cant see any markings on it for putting it back on..
    thanks
  7. darren
    If the rubber is no good you need a replacemnet balancer. Its a one piece assy.
  8. random hero
    random hero 1972 ford maverick I6
    hudson valley
    1972 maverick
    is that the balancer or the timing cover seal he's talking about?
  9. spork1o1
    spork1o1 Member
    Michigan
    can you post a pic?
  10. sierra grabber
    northern nevada
    i think you are talking about the seal?? if so you need to get a new one and replace it. should come in the gasket set for the cover.
  11. darren
    I got it now. May have misunderstood. Tough reading between the lines.:)
  12. fordmaverick72
    il post a pic tonight.july 17th some time. i got a 312 id liek to just throw in this winter.but i figured just that id do it this winter. i would still like to see this (250) motor running if i could help it. my wallets kinda empty.maybe il just say forget it and get a head start and swappin motors. thanks for all ur help.
  13. spork1o1
    spork1o1 Member
    Michigan
    how do you get 312 cubes out of a 302.
    .030 is only a 306 is it not?
  14. rthomas771
    Who counts an overbore to add to cubic inch? A .030 over on a 302 is still a 302 in my book. Now if you stroke the crank then its a different ballgame
  15. Dave B
    I think you need to get a set of service manuals...it'll make things easier.
