Timing issue?
Discussion in 'Technical' started by Cameron, May 4, 2013.
  1. Cameron
    Cameron Member
    oklahoma city
    1977 Maverick
    Okay so all week I have been struggling with my mav. I have a stock carb that I have rebuilt, stock v8 engine, and I'm running straight pipes ( not sure if that matters). When I start the car it idles high yet when driving fast or coming off the highway and stopping at a stop light the car idles low to the point it kills itself I'm not quite sure whats up. Any ideas or suggestions?
  2. MSmithPDX
    MSmithPDX Member
    Portland, OR
    did you set themidle with the car fully warmed up? What kind of choke is on the carb?
  3. Moneymaker 1
    Panama City Florida
    First of all if the car is cold when you start it up, the fast idle could and should be due to the choke functioning properly, so from there, warm the car up to proper operating temp while sitting still and when the idle drops off (choke opens) see what it idles at then, if its a real low idle you can try and adjust it up a bit, if it is a rough idle you may have a vaccum leak, there should be an idle adjustment on it.
  4. Cameron
    Cameron Member
    oklahoma city
    1977 Maverick
    I have no clue what choke is on the car, I haven't replaced it so I assume the one that came with it.
  5. Rayell
    Rayell Member
    Lizella, GA
    1975 Maverick, 1963 Falcon Ranchero, 1993 Ford Ranger, 2000 Ford Taurus
    If your car is running fast with the chock closed, this is normal with a cold engine. When the car gets warm, and the chock opens causing the engine to lower the rpms at idle. Do as the others said, crank the car and let idle until the choke opens, and then set the idle to approximately 650 rpms. If you do not have a tachometer you can turn the screw on the idle adjustment clockwise to increase the rpm up to a comfortable sound. Try doing this until you can stop the car on the level without chocking down, or creeping forward without your foot on the brakes.
  6. Bryant
    all the coments on the choke are correct. the open exhaust can also contribute to the the stalling. a motor needs some back pressure to run correctly. you should be able to raise your idle rpm and that should take care or your problem
  7. 75 Vomet
    75 Vomet Member
    Shickshinny, PA
    75 Comet GT, 03 Ranger, '11 Fusion,'13 Escape S
  8. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    No engine "needs backpressure". For maximum performance, the intake system needs to be matched to the exhaust system, but an open exhaust would not cause stalling.
