What was the stock tire size on the maverick? The tires on the car I got look a little big it might just be me any help would be appreciated Kyle
I would suggest 205/75....which would be bigger than what you have now. 185's are pretty small in my opinion.
1976: Standard C78X14 Optional BR78x14, BSW CR78X14, BSW/WSW, DR78X14, BSW/WSW, DR70X14 RWL SPACER SAVER TIRE EXCEPT WITH RADIALS TIRES.
Do mean big as in tire diameter? also the wheel width affects the end tire size. 185 on a 4" wheel will be different than a 185 on a 6" wheel. The stock tires were around 25" so i'd advise staying in that range so your speedo will register correctly. And like craig said at least a 205, 215 on a 6" wheel is perfect IMHO for all around driving.
i have 205/75/14 and I wish I could bet a taller tire but it's getting hard to get good (keyword good) 14"/15"/ tires today. i want a taller tire to get my rpm's lower on the highway. Here is a ROCKIN tire height calculator http://www.1010tires.com/TireSizeCalculator.asp
