Tk5?
Discussion in 'Transmissions' started by Trojan, May 20, 2014.
  1. Trojan
    Trojan Member
    Bakersfield California
    1972 Mercury Comet
    So my dad is going to be picking up a maverick grabber this saturday and we found a 2.8l and a tk5 out of an 85 ranger and wanted to know if it would bolt right in,need modifications,or what?Any input would be greatly appreciated
  2. Craig Selvey
    Bolt right in? No.
    Modifications? Yes.
  3. Trojan
    Trojan Member
    1972 Mercury Comet
    how intensive are the modifications?have you done it?has anyone?
  4. Craig Selvey
    I have never done it, but it all depends on your skill level. If one had no skills....the modifications will be extensive. This set up was never available from the factory, so it will take a lot of work.
  5. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Question is why would you want to put a 2.8 in? Aren't these engines know for not being very reliable?
  6. rthomas771
    85 Rangers came with a Mazda (2WD) or Mitsubishi (4WD) transmissions bolted to the 2.8 and 2.9 engine. Are you sure it is a t5?
  7. MSmithPDX
    MSmithPDX Member
    Portland, OR
    http://www.therangerstation.com/tech_library/ManualTransmission.html
    His should be the Mitsubishi transmission it's a 5 speed.
    I'm familiar with the Mazda transmissions, they suck, I wouldn't put one on a go-cart. The Mitsubishi transmission was weaker if I recall.
    I would say, the 5 speed will require serious and considerable fabrication to get it in the tunnel, and the shifter in the car. You WILL be making a new access point to the shifter, as it will be about a foot closer to the firewall.
  8. rthomas771
    I had to replace the cluster gear in my old 85 Ranger 4x4...and I always drove the truck like an old lady. I couldn't imaging a transmission weaker than the Mitsubishi.
