too hot for the maverick
Discussion in 'Technical' started by justin has a 74, Apr 14, 2010.
  1. justin has a 74
    kentucky
    Well today i went driving around in 85 degree weather like an idiot, got home and tried to start up the car again (dont ask, im just weird like that)
    car turned over REAL slow like the distributor was set too advanced. moved it a little and the same thing happened. was the car too hot?:D ive heard of overheating but never experienced a car not starting because its hot. Just trying to figure this out.:hmmm: temp was 193 with 180 thermostat.
    went out half an hour later and turned over fine.
  2. Mavman72
    Heat soak into the starter...You have headers right???
  3. justin has a 74
    kentucky
    yes, am i going to need one of them fansy heat shields for my starter?
  4. Mavman72
    I would think thats the route to go but... Check your battery and cables/connections as well. Bad cable/ground will give you the same symptoms. Good luck!!!
  5. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Get a newer gear reduction starter, they work much better than the old ones. It will be money well spent.
  6. baddad457
    Did you mount the battery in the trunk ? I did with mine and thought I had big enough cables, but apparently not. It would do the same thing. Moved the battery back up front and it's never done it again.
  7. ladyeclectic79
    ladyeclectic79 Veni, vidi, vici
    Hanford, CA
    A '73 and a '70 Maverick
    Where would I find one, or part #? They would bolt up to the V8 engine? My starter's on the fritz too, works but sounds like a stuck pig when you try to turn it over.
  8. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    I went to oreilly's and asked for a starter from an 82 mustang 5.0,its cheap smaller and cranks alot harder.
  9. maverick75
    http://mmb.maverick.to/showthread.php?t=40882
  10. justin has a 74
    kentucky
    it happened when the car is hot so im leaning torward the heat shield and not a cranking problem. the headers are about an inch away from the starter and its a 91 mustang model about 10 months old.
  11. justin has a 74
    kentucky
    nope, still in the front
  12. baddad457
    Put the biggest battery cables you can find on it and then try it again. My cables are about a half inch in diameter and even hot it spins the starter on the 331 like its got a 4 cylinder in there. And this is a 10.5 to 1 comp motor.
  13. justin has a 74
    kentucky
    ive had this car for 2 years and have had the headers on for about 2 months, this has never happened before so i highly doubt its the cables(y)
  14. tim keck
    sharps chapel,Tn
    Sometimes, starters get old. They tell you it's time to replace. Ran headers on my 302 Mavericks with no heat related starter problems. Get a new starter and some heavy gauge cables while you're at it. Should fix it right up.
  15. darren
    Grab a heat shield for the starter. Bet it helps.
