Tore into the motor today
Discussion in 'General Maverick/Comet' started by BigDog41364, Jul 26, 2015.
  1. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    For those who where at the MCCI Roundup Nationals this weekend and helped me out with the motor issue, thank you very much. For those who where not there, We got about 80 miles away from the hotel and the motor started ticking at idle, thought it was a lifter so we continued on. When we pulled of the high way it was knocking pretty bad. Going down the highway it was not noticeable, but when you stopped it was bad. Well the wife and I pulled it apart today and found out what went bad. The #4 piston is destroyed. not sure why but the piston and block are trashed. there is .018 in wore off the side of the piston, it rattled around in the cylinder. I hope to have another 302 rebuilt and in the car by next weekend. IMAG0431.jpg
  2. z28th1s
    Lynchburg, VA
    Sorry that you had problems at the MCCI Roundup Nationals. I knew it sounded like a pretty serious issue when you pulled up in the hotel parking lot.
    At least you were still able to enter your car in the show! Good luck with the new motor!
  3. Craig Selvey
    Wow....that looks bad!! Amazing you made the last 80 miles.
  4. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    I found a 69 302 out of a Ranchero, going to go look at it today. I'll rebuild the short block and put my top end on it, should have it running in a week or so. While I have it out I'm going to lower the Rod & Custom mounts. the motor sits about 1 1/2 in taller than stock. it looked like i can lower it without issue.
  5. bmcdaniel
    How does the #4 rod bearing look? That's where the oil gets thrown from to lube the cylinder wall.
  6. Mercurycruizers
    Venetia, PA
    So sorry that you need a new motor. Glad you made it to the roundup. Was nice to meet you. Hopefully we'll see you next year. Good luck on getting a new motor in the car....
  7. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    The rod and main bearings look good. I had 60lbs oil pressure the hole way there.
  8. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    We pulled the 69 motor apart yesterday, it's well used but in good shape. The cylinder walls look really good. It has the 8.9 cr pistons. with my aluminum heads it should end up around 9.5- 10.0 cr. I'm happy with that.
  9. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    Wow....lowering the mounts turned out to be a large undertaking. I should have it buttoned up today I hope. Then we should be able to drop the new motor in this weekend
  10. 71gold
    will that effect the pinion angle?
  11. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    The MII raised it up, I'm just lowering it back down.
  12. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    New 69 302 is ready to install. Unfortunately I have to work 12 hours Friday,Saturday and Sunday so it will have to wait till Monday.
    Ronald Hopkins and Craig Selvey like this.
  13. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    A little more done....Back on 12hrs for a couple of days...should be running Friday IMAG0448.jpg
    mojo and Craig Selvey like this.
  14. Kenn
    Kenn Member
    1995 Ford F150, 2005 Ford F150
    Progress looks good.:cool:
  15. mojo
    Looks great Rich! Like all the room in the engine bay. Hope to catch you nx month at NSRA if you plan on coming again.
    Hope you get worked out to your satisfaction.
