Torque Converter and Flexplate balance
Discussion in 'Technical' started by gdemopesq, Feb 11, 2009.
  1. gdemopesq
    gdemopesq MOTOR CITY MAV
    Michigan
    72 Maverick 302
    I just ordered my torque converter. The specs say it was balanced. So I ordered the flex plate at 0 oz. nuetral balance. That was the right move.....right?
    Someone had previously gave me a link to Mustang Central C4 info and I think I am on the right track. Let me know.
    Thanks
  2. Dave B
    What year is your engine? You need to match the flywheel balance with whats correct for the engine you have.
  3. gdemopesq
    Michigan
    72 Maverick 302
    its a 72-302
  4. gdemopesq
    Michigan
    72 Maverick 302
    should i have got a 28oz. it seems if the TC is balanced shouldnt the flexplate?
  5. yellow75
    Tillamook Oregon
    Yes you need to have 28oz flexplate
  6. 71gold
    that means it runs ..true...not wobbly.
    like balancing a wheel or driveshaft.
    like Dave said...the balance is in the motor...(flexplate and harmonic balancer)...to the crank...:tiphat:
    ...Frank...:Handshake
  7. gdemopesq
    Michigan
    72 Maverick 302
    Thanks I called summit and changed the flexplate to the 28 oz, so i saved $14 thanks, it is still getting shipped tomorrow so I can have fun this weekend. You guys are pretty sure I needed the 28oz with a balanced torque converter?
  8. don graham
    All the early 302's had a 28 ounce flexplate. I posted that web site. All 302's are externally balanced.
  9. gdemopesq
    Michigan
    72 Maverick 302
    thanks Don
  10. PINKY
    PINKY .....John Ford.....
    Louisville, Ky.
    1970 Ford Maverick
    Two completely different animals.....you did right by changing your order :thumbs2:
  11. PaulS
    Torque converters are always zero balanced - just like clutch pressure plates. They are a replacement item and the zero balance mans that you don't have to rebalance your engine if you have to replace them.
    The flex plate and flywheels have an off-set balance to help balance the crank and sould be balanced with the crank in any performance engine.
  12. kukm66
    kukm66 Member
    Phoenix
    1972 Grabber, 1964 Falcon Futura Convertible, 1964 Ranchero
    Early 302's use the 28 oz flexplate. From 1985 onward, all 302/5.0 use a 50 oz flexplate.
  13. 71gold
    not "all", my '91 5.0 has a 28oz...:yup:
    the flexplate goes with the...crank...
    ...Frank...(y)
  14. kukm66
    kukm66 Member
    Phoenix
    Frank:
    Is that the original crank?
  15. 71gold
    no...and that's why ..."the flexplate goes with the crank"...
    ...Frank...
