torque converter problems
Discussion in 'Drag Racing' started by idrivemav, Aug 14, 2010.
  1. idrivemav
    idrivemav Member
    texas
    1975 maverick
    went to the track today the car ran good but on the first pass the converter wouldnt stall its a 3500 stall and i couldnt get 1500 rpm at the line i ran 12 passes tonight it never got any better ive got a spare converter thats goin in tomorrow it sucks i got outran by a lambo gallardo i ran a 13.28 to his 13.19 my car usually runs 12.50s its amazing what a lower stall can do to your times
  2. racereadyfab
    racereadyfab Member
    Chandler,IN
    72 maverick
    Are you foot breaking or using a transbrake. If your footbreaking getting it to go to 3500 will be impossible. If you are questioning the stall speed, the best and easiest way to check it is to drive the car about 10-15 mph in high gear, stare and the tach and mash the loud pedal. Watch the tach as it will flash to the stall speed and hesitate for a moment. When it hesitates thats close to the stall speed. Hope this helps ....Brian
  3. mavman
    mavman Member
    Arkansas
    Is it a new converter?
    If it is supposed to be a 3500 and it's that doggy, it may be possible that the sprag is broken. That'll sure cause a low stall speed...and it'll be a slug off the line because the sprag is supposed to be stationary which multiplies torque. No torque multiplication=low performance especially in our small block cars that need as much torque multiplication that they can get. Relatively speaking of course. Relative to the "norm" 555, 565, and 598" big blocks that are so common nowdays.
    Only way to know if a sprag has failed is to (1) open the transmission and inspect the pan for metal shavings or (2) pull the converter out and have it cut open.
    Was it a custom converter of an off-the-shelf generic deal?
  4. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    Sounds like wrong converter to start...10" or what is it?
  5. idrivemav
    idrivemav Member
    texas
    1975 maverick
    the sprag gear was brocken and had some bent blades i put the new converter in today it ran alot better but it had street tires on it so it spun for about 80 feet the broken converter is one i had a local trans shop make its been in the car for 2 months the new converter is another local trans shop converter it has a garuntee so hopefully it wont break after the install i was on the highway headed home and a new c6 vette started messin with me i pulled on him to i dont know how fast it made my day alot better
  6. mavman
    mavman Member
    Arkansas
    If it's a race car, have the sprag removed and have them put a hub in it to make it spragless. One less thing to go wrong and more consistent-especially in the 1/8 mile. However you probably don't want a spragless on a street car as they aren't as efficient at cruise speeds and they create a little more heat.
