torque specs for torque converter nuts
Discussion in 'General Maverick/Comet' started by russellgaspard, Jul 20, 2014.
  1. russellgaspard
    russellgaspard Member
    united states
    1973 Ford Maverick 250 Inline 6
    I have a 250 inline 6 and couldn't find the torque specs for the 4 nuts on the torque converter. Does anyone know what I need to torque them to?
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Tight.
  3. russellgaspard
    united states
    I would rather know the torque. I dont want to just go guessing on things like this
  4. Dave B
    Did you try the search feature?
  5. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Won't be easy to get a torque wrench on those nuts.
  6. Bryant
    if you cant find the factory specs, try searching for a general torque spec for the size of the stud.
  7. Bryant
  8. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    Sure it is.
  9. 71gold
    X-2...:bouncy:
    it really isn't holding anything down...just on. the converter can't go anywhere if all of them are loose. it's not a biggy. I've never torqued one and have done 20 or more...:huh:
  10. Bryant
    if the nut is loose the studs and nuts will eat away at each other till the holes get elongated and the studs snap off.
    also too tight can stretch the studs to the point of failure.
  11. russellgaspard
    united states
    lol exactly what you just said is why im wanting to find the correct torque. But if worse case I cant find the specs ill just use the torque specs for the v8. It says to tighten the torque converter on the v8 to 50 ft. lb.
  12. Bryant
    thats why i posted the link to the engineering page of torque values. i dont remember if the studs on the converter are 3/8s or 5/16s. they are grade 8.
    3/8s calls for 47 ft/lbs
    5/16s calls for 29 ft/lbs.
  13. russellgaspard
    united states
    they're 3/8s! Thank you! :)
  14. 71gold
    you are talking about a worst case ...with all of them loose. as before...never... had one come loose.
