Torque specs on torque converter nuts?
Discussion in 'Technical' started by AppMaverick, Jun 21, 2011.
  1. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    Hey! Can't find it in chilton's or searches.. Is there a torque spec for those 4 nuts attaching the flexplate to the torque converter on a 302/C4 combo?
    Thanks in advance!
  2. rthomas771
    Converter to flexplate 23-28 ft. lbs.
    Engine to transmission is 23-33 ft. lbs.
    Edit: also says engine to trans is 40-50. I thought that other number was kinda loose
  3. AppMaverick
    AppMaverick Member
    Raleigh, NC
    1971 Maverick 2dr
    Sweeeet! Thanks! Gonna get this done TODAY! :thumbs2:
  4. baddad457
    I've never used a torque wrench on any of those bolts or nuts. Just get em tight. The transmission to engine bolts need to be at least about 50 ft/lbs as these are the same size as the head bolts, but a slghtly lower grade bolt. (head bolts are 70-80 ft/lbs) Id think the converter nuts could go to about 45 ft/lbs, being a 3/8" NF thread.
  5. PaulS
    The stock converter to flex-plate bolts are 5/16 NF and the spec is 25 foot pounds.
    The bell to engine bolts are 7/16" NC grade 5 and the recommended torque is 45 foot pounds.
  6. baddad457
    I've never seen converter nuts that were 5/16"NF. Every one I've seen on a Ford were 3/8NF
