tower to cowl braces
Discussion in 'General Maverick/Comet' started by whitey68, Jun 24, 2011.
  1. whitey68
    whitey68 Member
    springfield illinois
    71 comet gt 65xxx orig miles .. 69 mercury marquis 2dr hard top land yaught, 62xxx orig 2 owner 429 4bbl 2000 heritage softail
    how important are the shock tower to cowl braces? i know theres a reason for them but new from the factory these cars wern't exactly pavement killers.
  2. 71gold
    depends on who you ask...:yup:
    me...i don't think they are that important. I've ran with and without them with no difference either way...:tiphat:
  3. simple man
    simple man Member
    Bunnell,Florida
    " Depends on who you ask "- - - I personally would use them. They help to keep your front end geometry stiffer. Sure you can run without them, but if I just paid for a front end alignment, it would be with them installed!:)
  4. Earl Branham
    Lugoff, SC
    I personally think that anything you do to strengthen the front end on these cars is very important. They move around a lot, and you can see a lot more cowl shake without the supports.
  5. injectedmav
    injectedmav Member
    Georgia
    I say use them. I have cracked both shock towers myself, Mustang owners have all manner of issues cracking the front end in multiple locations as well(same suspension/unibody design). Without them, the weight of the nose is soley supported on the lower frame rail and torque box. The weight is designed to be triangulated into the upper firewall seam from the frame rail to spring tower to firewall. The torque boxes were never intended to carry the entire weight of the front end. These cars can handle ok with the right combo of parts and geometry correction and additional bracing in the tower area as well as tying the lower frame rails together.
    I can't take credit for that info. I spoke with the guy who designs the FMF front ends for street rods at a F100 meet back in 04 who, at the time was working on a front end upgrade that would be supported by the originally designed structure and didn't require cutting the car to install it. He already had the Mustang kit available and has since released a front "Module" that welds in at the firewall, eliminating the factory front suspension and framework altogether.
  6. darren
    i figure if they werent needed ford wouldnt have wasted moiney on them. especially on the frugal mavs and comets.
  7. mojo
    I agree. I believe the Ford folks/engineers spent a lot of research time and tests, and decided they were necessary. I believe they even use some kind of supports on the current model Stangs. Im keeping mine. The only problem I have w/ them is they are in the way "sometimes" when ur workin under the hood.
  8. Jsarnold
    Jsarnold Senior Member
    Raleigh, North Carolina
    '72 Sprint
    But, they make great parts trays!!:D
  9. zorares
    zorares Member
    Midlothian, Texas
    1973 Ford Maverick
    you can also slow cook steaks on them on long trips. :thumbs2: :rofl2:
  10. 71gold
    :hmmm:...no one can think of anything Ford wasted money on...:huh:
    ...:rofl2:...
  11. b_ryce70Mav
    b_ryce70Mav Member
    Shaw AFB, SC
    That's their primary purpose!
  12. whitey68
    whitey68 Member
    my driver side was gone when i bought it, the po put power disc brakes on it and left the brace off. i found one on flea bay for 25 bucks for a pdb car it was a pain to put on, had to customize it lol
  13. Mavman72
    Ford wasted tons on the Contour and Mistique...Talk about bad news cars...:burnout:
  14. bmcdaniel
    I drove mine one time without the braces, felt like the front end was gonna fall off. But this is a car with a V8 that originally had a 6 cylinder and there was no belly bar either.
  15. injectedmav
    injectedmav Member
    Georgia
    an Aspire
    a Contour
    a Lincoln Mark 7 diesel
    Jack Nasser's paycheck!:biglaugh:
